Full Version: Xbox-sky torrent browser
first things first. this is not my script. it is the coding of enigma644. i noticed no one has posted about it so i am going to bring it to your attention. this is the email i received from enigma:
'hi,
this message is going out to everyone who emailed me about my xbox torrent script.
now that suprnova is gone for good, i have decided that the next best torrent site out there for xbox stuff is xbox-sky [http://bt.xbox-sky.com:8080/index.php]
the guys at xbox-sky have been awesome and have setup a url specifically for my new torrent script!
please note that xbox-sky requires a username and password, but don't worry, it doesn't cost anything! so head on over to their website and setup a username before you use my script.
once you've got your username, you can stick it into the script, or use the options button.
anyway, if you lot have all hacked your xboxs, i'm sure you're smart enough to figure out how it works!
let me know if you find any bugs!
james [enigma644]'
it can contact abc like all the other torrent scripts.
the following is an extract from the script. these need editing before use. also - this isnt mentioned - you need to edit the username and password as mentioned in the e-mail.
'# modify the settings below to specify where you want the .torrent file to be saved.
# your options for savings are:
#                   - locally on the xbox harddrive
#                   - ftp to server
#                   - abc autodownload.'
you put your user and password for 'http://bt.xbox-sky.com:8080' here:
# xbox sky settings
trackername = "xbox sky"
skyusername = "username" <<<----here
skypassword = "password"  <<<----and here
you need to open the script in notepad yourself to see exactly what needs editing.
attached was the script. so here it is!
download here:
http://ek-clan.vxcomputers.com/enigma644...ts-sky.zip
yo xbox-sky.com wont let anyone submit any new reg. so any word on when that bs will go back to normalHuh??
