Full Version: Bug: pre eden filenames in file mode are changed by xbmc
I just noticed that in the pre eden version from 11.sept. 2011. Filenames are changed by xbmc in the normal list view at file mode.
The folder is set by content "Music videos".
In file mode than in all view modes the musicvideos which are known in the database are shorten by xbmc. (Just showing the song name!)
So there is no chance to get a list with the normal filenames. And a list with only showing song names are not usefull.
I assume in file mode no change should be done by xbmc!
Otherwise it would make sense the user could decide what is shown in the list.
flip the switch in video settings..
Thank you Spiff I found it you are right there is the switch for showing meta data! So its not a bug just a user problemSmile
