2011-09-14, 02:21
First of all, here is my log. Its from my MacBook's XBMC, but the following happens at both my ATVs aswell.
I'm unable to load subtitles while watching a movie/tvshow. Files are named like this (all in the same directory):
tvs-lost-dl-bd-xvid-106.avi
tvs-lost-dl-bd-xvid-106.sub
tvs-lost-dl-bd-xvid-106.idx
As you can see in the log, on the one hand, it takes ages until that episode is starting (about a minute, without subs in the folder approx 2seconds) and then i'm unable to load the subs. If i enter the subtitles menu in Confluence, i can see a window for about 0,5sec and then it returns to the playing episode. If i click on the audio symbol and try to active subtitles there, XBMC does not recognize any subs and shows "none". When i hit "Search subs" i can add the .sub or .idx file, the playing file freezes for some seconds (just picture, sound is playing fine) but not subtitles come up. Any help? I have some shows without forced subs burned in so i need to add them manually. As i wrote in the beginning, i have the same prob on an OS X XBMC as well as on iOS. Tried nightlies 0831 until today.
Regards.
Edit: It seems to be Confluence related, in PM3 everthing is working fine expect the long loading time when subs are in movie/tvshow dir.
Edit2: .srt subs are playing fine, file is starting immediatly so i guess its not only skin related
Regards.
