Full Version: problems with radio-stream
hi all
first, thanks for all who makes xbmc the best mediacenter which I ever saw.
i love it!
i have just a little problem. Every time I try to start a radio stream over a webinterface (for example awx) or also over any android apps or iphone apps i get the following error;
17:18:18 T:2628369264 M:3449946112 NOTICE: -->Python Interpreter Initialized<--
17:18:18 T:2628369264 M:3448676352 NOTICE: [ListenLiveEU]: Mode: 2
17:18:18 T:2628369264 M:3448676352 NOTICE: [ListenLiveEU]: URL: http://streaming01.sr-online.de/unserding_2.m3u
17:18:18 T:2628369264 M:3448676352 NOTICE: [ListenLiveEU]: Name: 103.7 UnserDing | Saarbrücken | Youth programming | 128 Kbps
17:18:18 T:2628369264 M:3448676352 NOTICE: [ListenLiveEU]: > playStream() http://streaming01.sr-online.de/unserding_2.m3u
Here I get a short break (maybe 3-5 seconds) I think the stream is loading here....
17:18:24 T:2628369264 M:3448020992 NOTICE: [ListenLiveEU]: < playStream() isPlaying=1
17:18:25 T:3020015488 M:3447386112 NOTICE: DVDPlayer: Opening:
17:18:25 T:3020015488 M:3447386112 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
17:18:25 T:2678725488 M:3447386112 NOTICE: Creating InputStream
Then I hear the radio stream for ca. 1 second
17:18:25 T:2678725488 M:3447386112 ERROR: CDVDPlayer::OpenInputStream - error opening []
17:18:25 T:2678725488 M:3447386112 NOTICE: CDVDPlayer::OnExit()
17:18:25 T:2678725488 M:3447386112 NOTICE: CDVDPlayer::OnExit() deleting input stream
17:18:25 T:3020015488 M:3447386112 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.listenliveeu/?url=http%3A%2F%2Fstreaming01.sr-online.de%2Funserding_2.m3u&mode=2&name=103.7+UnserDing+%7C+Saarbr%C3%BCcken+%7C+Youth+programming+%7C+128+Kbps]
17:18:25 T:3020015488 M:3447386112 NOTICE: CDVDPlayer::CloseFile()
17:18:25 T:3020015488 M:3447386112 NOTICE: DVDPlayer: waiting for threads to exit
17:18:25 T:3020015488 M:3447386112 NOTICE: DVDPlayer: finished waiting
then it breaks off...
It is for me very strange....because, if i play the same stream direct in xbmc, all things are OK;
Here the logs, when i play it direct;
17:24:34 T:2650401648 M:3452563456 NOTICE: -->Python Interpreter Initialized<--
17:24:34 T:2650401648 M:3452309504 NOTICE: [ListenLiveEU]: Mode: 2
17:24:34 T:2650401648 M:3452309504 NOTICE: [ListenLiveEU]: URL: http://streaming01.sr-online.de/unserding_2.m3u
17:24:34 T:2650401648 M:3452309504 NOTICE: [ListenLiveEU]: Name: 103.7 UnserDing | Saarbrücken | Youth programming | 128 Kbps
17:24:34 T:2650401648 M:3452309504 NOTICE: [ListenLiveEU]: > playStream() http://streaming01.sr-online.de/unserding_2.m3u
17:24:39 T:2650401648 M:3451473920 NOTICE: [ListenLiveEU]: < playStream() isPlaying=1
17:24:39 T:2650401648 M:3451473920 ERROR: EndOfDirectory - called with an invalid handle.
I have the same problem with other radio plugins...like icecast....
here the logs if i play it over web;
17:29:27 T:2840234864 M:3448881152 NOTICE: -->Python Interpreter Initialized<--
17:29:27 T:2840234864 M:3446235136 NOTICE: ### [Icecast] - Using SQLite!
17:29:36 T:3020015488 M:3445288960 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.icecast/?play=http://213.177.96.6:9900/wizard]
and here if i play it direct;
17:30:18 T:2678725488 M:3446996992 NOTICE: -->Python Interpreter Initialized<--
17:30:19 T:2678725488 M:3445592064 NOTICE: ### [Icecast] - Using SQLite!
does someone have a solution for this problem?
thanks!
