Full Version: M4V audio problem, stereo plays fine, 5.1 AC-3 choppy
I have a few movies in M4V. In Stereo they work and playback fine, when I switch to 5.1 the audio and video get choppy.
My system:
Windows 7 64 bit, XBMC 10.1
ASRock AMD Zacate E-350
4GB of RAM
I have no codec packs installed.
Here's a read out of a few of the movies in question:
Video #1
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 47mn
Bit rate : 3 000 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.180
Stream size : 2.25 GiB (84%)
Writing library : x264 core 80 r1373 4322f63
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=2 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.3 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=4200 / vbv_bufsize=2100 / ip_ratio=1.41 / aq=1:1.00
Language : English
Material_Duration : 6461580
Material_StreamSize : 2411510902
Material_FrameCount : 154923
Video #2
Format : JPEG
Codec ID : jpeg
Duration : 1h 47mn
Duration_LastFrame : -2mn 18s
Bit rate mode : Variable
Bit rate : 987 bps
Width : 640 pixels
Height : 272 pixels
Frame rate : 0.003 fps
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.890
Stream size : 883 KiB (0%)
Language : English
Encoded date : UTC 2011-08-19 16:48:03
Tagged date : UTC 2011-08-19 16:48:03
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 47mn
Bit rate : 160 Kbps
Maximum bit rate : 219 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 123 MiB (5%)
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : ac-3
Duration : 1h 47mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 296 MiB (11%)
Language : English
Encoded date : UTC 2011-08-19 16:47:39
Tagged date : UTC 2011-08-19 16:47:49
Text
Format : Apple text
Codec ID : text
Duration : 1h 47mn
Bit rate : 1 bps
Stream size : 519 Bytes (0%)
Language : English
Encoded date : UTC 2011-08-19 16:47:49
Duration_LastFrame : -138420
Video
Format : AVC
Format settings, CABAC : No
Codec ID : avc1
Duration : 1h 29mn
Bit rate : 3 072 Kbps
Height : 694 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.144
Stream size : 1.92 GiB (85%)
Writing library : x264 core 83 r1391 3d0f110
Encoding settings : cabac=0 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=2 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3072 / ratetol=1.3 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=10000 / vbv_bufsize=5000 / ip_ratio=1.41 / aq=1:1.00
Language : English
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 29mn
Bit rate : 160 Kbps
Maximum bit rate : 251 Kbps
Stream size : 103 MiB (4%)
Language : English
Audio #2
Format : AC-3
Codec ID : ac-3
Duration : 1h 29mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 247 MiB (11%)
Language : English
Encoded date : UTC 2010-03-09 19:21:57
Tagged date : UTC 2010-03-09 19:22:02
Thanks for any help
how did you connects your system?
What do you mean?
I have DXVA enabled, full screen window instead of true full screen, video is out via HDMI and sound is out via toslink optical.
|Tch0rT| Wrote:What do you mean?
is this how you connects it-
htpc>hdtv via hdmi
htpc>avr via toslink
Yes.
please follow the guide in this enclosed doc- xbmc settings.
Thanks! That worked. Big Grin Appreciate it!
