2011-09-15, 17:13
Hi all,
I'm putting the finishing touches on my HTPC setup and have noticed one major bug that may or may not be a result of my ignorance about something:
I'm using the nightly builds also. So, sometimes, when my HTPC idles with XBMC up and goes to sleep, upon wake, the library is gone and needs to be rebuilt for both movies and tv shows manually. I've tried reproducing this problem when sending a powertoggle command to force the HTPC to sleep and to wake it, but the library was intact. However, when letting the HTPC idle and trigger sleep, it has happened twice now.
I can verify that connection to the remote shares works fine. It's just an internal XBMC library issue.
