2011-09-15, 21:08
Is there any kind of remote that is similar to the Harmony series but that would allow you to actually browse your XBMC library as well on the remote iteself?
I like how you can choose specific things and it would set up your devices.
For example
I could make a music button, it would switch my amp to the HTPC but not turn the TV on.
But then I would need a separate remote (android tablet) with the XBMC remote to then control the music.
Im trying to find a way to control it using as little remote as possible and as simply as possible
The goal is to use the HTPC to play music without using the TV.
For example
