Full Version: Alternative .strm file for IceLibrary
Would it be possible to add another file extension that is executable like .strm?
The .strm is general used as live streams, so if you watched it, you wouldn't really want to mark it as watched. But when you use IceLibrary, you would want the stream after you watch it, to be marked as watched.
Would it be possible to add an extension .xstrm for this purpose?
You can manually mark those videos as watched.
Sranshaft Wrote:You can manually mark those videos as watched.
True, but it don't get done automatically.
I'm pretty sure the reason why strm-files aren't marked as watched is because they are playlists.
I don't think the developers of XBMC should build XBMC to fit a plugin. I do however think it would be great if XBMC got a non playlist fileformat able to run plugins or streams just like strm-files. I'm sure a lot of interesting plugins/addons could make use of such a fileformat.
