2011-09-19, 12:23
2011-09-19, 21:36
Problem "solved"
Well... kinda.
After some testing I noticed it did work from my homepage, but not from HFS. Comparing the html source of both, I could see some big differences. Since HFS gives you the option to create a template which it uses to serve its files, I tried modifying this template to have a similar layout as from a normal webbrowser.
This finally did it. I wouldn't call it the prettiest template, I just modified the working html into a template, using most of the default HFS template. I left the template on pastebin, for whoever's interested.
I do have another question. The whole reason for doing this, was so I can share my library with my parents over the internet. I was already using FTP for it, but I remember being told once that HTTP(S) was a better option. However, I was also browsing the wiki again today, and there the same comment is placed by both FTP and HTTP -> Not really suitable for streaming, so don't use as a video or music source.
So, any opinions which should work better or has more support? (Do either retrieve the audio/video codec info beforehand, so you can see if a movie is SD/HD?)
Remco
Well... kinda.
Remco
2011-09-19, 22:29
HTTP not suitable for streaming? I guess no one ever told Youtube/hulu/etc.
I would agree with FTP not being as good, though. HTTP includes content-type header which will help, and it's pretty fast with low overhead.
I've never used HFS, but I would guess that a basic index would be fine, like apache indexes.
2013-08-20, 19:34
Did you use the "Web server directory" option to add your server ?
I want to be able to do this myself, but I've only gotten an empty list, as you did. I will try to change the template, thank you for adding it.
