Full Version: Web interface on Apple tv 2
Hi there.
I read theres a web interface for xbmc.. But not on Apple tv2? Where did it go, can it be enabled? It would be so nice instead of using that darn apple remote Smile
Thanx
http://[your_ATV2's_IP_address]:8080
example: http://192.168.1.4:8080
(if your IP was 192.168.1.4)
find you ATV2's IP address in the system info (found as a sub menu item of the settings in the Confluence skin)
works for me, but imo its a bit sluggish. If you've got an iOS or android device you'd be better off using a dedicated app for XBMC control
