I would like to implement a search feature in my addon and would like to know if anyone has an example to open the search dialog and then return a string that i can use
ie
open dialog:
searchtext = getkeyboadtext
url = 'http://www.xxxx.com/search' + url
thks
divingmule Wrote:Code:
searchStr = ''
keyboard = xbmc.Keyboard(searchStr,'Search')
keyboard.doModal()
if (keyboard.isConfirmed() == False):
return
searchStr = keyboard.getText() #.replace(' ','+') # sometimes you need to replace spaces with + or %20
if len(searchStr) == 0:
return
else:
return searchStr
Thanks Divingmule, worked fine once i figured i had to use it in a function due to the returns
Also if a user cancels, how do you make it so the page does not continue on to the next page and then shows 2 little dots (back dir) at top of page.
thanks
Good question, I don't know.
Anyone else ?
I managed to find out why after selecting ok on a dialog box why it continued to the next page anyway.
By default addon.end_of_directory() is called
ie.
if not play:
so i comment out these 2 lines and add addon.end_of_directory() wherever in my code that i do want to goto a new page. usually after i have finished loading menus. That way when i click ok the end of directory does not get called.
elif mode == 'GetMovieSource':
html = net.http_GET(url).content
match=re.compile('<li class="searchList"><a href="#/mirror/(.+?)" onclick="switchMirror.+?">(.+?)</a>').findall(html)
x = 0
st = 0
streamfound=''
if match:
for url,name in match:
if ValidLinks(name) == 'yes':
x = x + 1
addon.add_video_item({'url':'http://tvsearch.co/i/application/ajax.php?op=switchMirror&vid=' + url} ,{'title': name})
#addon.add_directory({'mode' : 'GetLink', 'url' : 'http://tvsearch.co/i/application/ajax.php?op=switchMirror&vid=' + url , 'img' : '' }, name, '')
else:
st = 1
if streamfound == '':
streamfound = name
else:
streamfound = streamfound + ',' + name
if x == 0 and st == 1:
dialog = xbmcgui.Dialog()
dialog.ok('Streams Found', streamfound + ' Stream Found But Not Implemented')
else:
addon.end_of_directory() <<<< HERE
else:
dialog.ok('No Streams', 'No Playable Streams Found')
