I've installed a nightly build ( xbmc-20110919-030cfbc-master-atv2.deb) and I don't have the Fanart View in my video category.
I would like to know if someone have it. I Tried others skins ( Confluence Vertical and PM3.HD) and I don't find it.
Do you have it ?
thx
well, i installed the 20-Sep-2011 build and fanart seems to be an option, again..
nobody changed on that section ... just fyi ...
thx for replies.
Like iamjustme I think to install the 20-sept-2011
Do you remember where this option is ?
well i'm so confused ...
I've updated to the 03-oct build ( xbmc-20111003-fc543cb-master-atv2.deb.) and I don't have the fanart view.
How Can I fix it ?
Should I looked for guisettings.xml ?
Steve_ Wrote:well i'm so confused ...
How Can I fix it ?
I don't understand what exactly is missing. Do you have a video library added? When you go in to the Video section and bring up the side menu, what options do you have for view type?
I am fairly sure this is skin specific.
JWindebank Wrote:When you go in to the Video section and bring up the side menu, what options do you have for view type?
I have (in french) :
- Vignette = cover
- Larges Icones = Big Icons
- Grande Liste = Big List
- Liste = List
and that's all.
I don't have coverflow view, fanart view and wall view.
JWindebank Wrote:I am fairly sure this is skin specific.
I looked for Skin options and I don't see any "activate fanart view" or something like that. I also activate auto update for skin.
I tried others skins ( Confluence Vertical and PM3.HD ) and I don't have this view
what can I do ?
Any clues ?
EDIT:
I found the solution !! You must simply scan your video librairy WITH A SCRAPER . It's very simple but nobody tell me it !
