2011-09-21, 13:13
I experience a nasty distortion sound when a Movie starts or when I skip within the file.
I use Teufel Cinebar 50, which is a VirtualSurround-Soundbarsystem.
The manufacturer told me to check that my Mediaplayer should be set to direct output (bitstream) and not PCM.
ATV2 is set to 16-Bit sound. I understood that XBMC provides AC3 passthrough.
Note: the distortion doesn't happen with all video files:
most of the DTS-encoded movies work just fine, but mostly all of the DolbyDigital-encoded movies produce that short static noise.
I assume this it somehow related to the ATV2's relatively high default audio output level, which also seems to be the case with the Cinebar. This may accumulate to the problem.
Unfortunately I cannot adjust the input level of my VirtualSurround-Soundsystem.
While playing AC3/DTS-Files, the Volume Level in XBMC's context menu cannot be adjusted, either.
- Does this mean that ATV2 "bitstreams"?
- Can the Output Level be reduced within XBMC? Or is there another way to fix this?
