as requested I created a video plugin for the videos from
http://www.4players.de. With this addon you can watch trailers and videos about computer and console games. Most of them are delivered in a very good quality (720p).
I would be very happy if you could test it and provide feedback - feature requests (if possible) and bug reports are more than welcome
For now you can download it here:
https://github.com/downloads/dersphere/p...-0.1.1.zip
When its feature-complete and bugfree it will be available via the official xbmc.org addon repository.
Update: The Addon is now present in the official XBMC.org Addon Repository for Dharma and Eden-pre.
regards,
sphere
Installed and tested so far:
Installation from ZIP file: OK.
Playing PC videos: Excellent quality
Fast forward, fast rewind: OK.
Pause video, play again: OK.
Everything works like a charm
. Great work. Thanks a lot.
A little remark/change request: Perhaps it could be possible to show one or two great thumbnail(s) for a video instead of 4 or 5 little ones in a row where I can't see any details on my Bravia TV.
bj1234 Wrote:... Perhaps it could be possible to show one or two great thumbnail(s) for a video instead of 4 or 5 little ones in a row where I can't see any details on my Bravia TV.
thanks for testing (again) ;-)
regarding your request, my addon just passes the thumbnails from the website. The website uses javascript to iterate through the thumbnails which isn't possible with xbmc at the moment. I see no way of changing the thumbnails to be different at the moment, sorry.
regards,
sphere
Hi sphere,
I get an "Script error" by playing every video from 4players.
Could you please check it?
Thanks in advance.
bj1234 Wrote:Hi sphere,
Thanks in advance.
the website was changed - I updated the addon.
Please try this version and provide feedback!
regards,
sphere
bj1234 Wrote:It works again.
Thanks a lot
thanks for the feedback - I requested a pull to the official repo
get again an "Script error!: addon.py" error. I think they changed the site.
Could you please check it? Thanks a lot.
yes, they changed the video section of their website. I will have a closer look this evening.
thanks for reporting
regards,
sphere
I fixed the addon and also added a few new features.
Changelog is:
- Fixed scraper (Website changes)
- Now showing 50 items per page (before was 20)
- Now using 160x90px thumbnails
- added sort methods (playlist, date and runtime)
- added is_update function (pagination is better now)
You can download it here:
https://github.com/downloads/dersphere/p...-0.1.2.zip
Please report back if it works now - then I will request a pull to the official repo.
thanks,
sphere
The pagination is very user friendly at the top of each page and the thumbnails now have a perfect size.
...and the main thing: the plugin works great. I tested about 10 videos and all were played perfectly. Thanks
Only one question: Where can I change the sort method ? Or isn't this possible?
bj1234 Wrote:Only one question: Where can I change the sort method ? Or isn't this possible?
thanks for the report.
Where you can change the sort method is skin dependent. With Confluence you have to press <left> to see the sidemenu. In the sidemenu you can change the sort method.
Implemented are the following sort methods:
- Playlist (like in webpage)
- Date
- Runtime
But please keep in mind that the sort method only affects a single page!
regards,
sphere
Hi sphere,
today I get the script error with version 0.1.2 again. Could you please check it once more again?
Thank you.
Thank you.
it works here. Please check again and if it doesn't work send me a xbmc.log (debug mode in xbmc not needed).
regards,
sphere
Sorry. Doesn't work for me.
Here is a snippet of the XBMC.log (I have to shorten it due to character limit):
21:41:08 T:1680 M:4294967295 NOTICE: Running the application...
21:41:08 T:1680 M:4294967295 NOTICE: Webserver: Starting...
21:41:08 T:1680 M:4294967295 NOTICE: WebServer: Started the webserver
21:41:08 T:1680 M:4294967295 NOTICE: ES: Starting event server
21:41:08 T:1820 M:4294967295 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
21:41:08 T:2056 M:4294967295 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:41:08 T:2056 M:4294967295 NOTICE: UDP: Listening on port 9777
21:41:10 T:5552 M:4294967295 ERROR: CRemoteControl::Connect - failed to connect
21:41:12 T:428 M:4294967295 ERROR: WEATHER: Unable to get data: Invalid License Key.
21:41:14 T:5592 M:4294967295 NOTICE: -->Python Interpreter Initialized<--
21:41:14 T:5592 M:4294967295 NOTICE: False
21:41:15 T:5552 M:4294967295 ERROR: CRemoteControl::Connect - failed to connect
21:41:15 T:1808 M:4294967295 NOTICE: -->Python Interpreter Initialized<--
21:41:16 T:1808 M:4294967295 ERROR: Error Type: exceptions.TypeError
21:41:16 T:1808 M:4294967295 ERROR: Error Contents: unsubscriptable object
21:41:16 T:1808 M:4294967295 ERROR: Traceback (most recent call last):
File "C:\Users\Lutz\AppData\Roaming\XBMC\addons\plugin.video.4players\addon.py", line 86, in ?
plugin.run()
File "C:\Users\Lutz\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib\xbmcswift\plugin.py", line 330, in run
self.dispatch(self.path)
File "C:\Users\Lutz\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib\xbmcswift\plugin.py", line 129, in dispatch
return view_func(**items)
File "C:\Users\Lutz\AppData\Roaming\XBMC\addons\plugin.video.4players\addon.py", line 47, in show_videos
videos, last_page_num = scraper.getVideos(category, page)
File "C:\Users\Lutz\AppData\Roaming\XBMC\addons\plugin.video.4players\resources\lib\scraper.py", line 41, in getVideos
title = link['title']
TypeError: unsubscriptable object
21:41:16 T:1680 M:4294967295 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.4players/category/PC-CDROM/1/
21:41:16 T:1680 M:4294967295 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.4players/category/PC-CDROM/1/) failed
21:41:16 T:1104 M:4294967295 NOTICE: -->Python Interpreter Initialized<--
21:41:16 T:1104 M:4294967295 NOTICE: False
21:41:20 T:5552 M:4294967295 ERROR: CRemoteControl::Connect - failed to connect
21:41:28 T:1680 M:4294967295 ERROR: Previous line repeats 1 times.
21:41:28 T:1680 M:4294967295 NOTICE: Storing total System Uptime
21:41:28 T:1680 M:4294967295 NOTICE: Saving settings
21:41:28 T:1680 M:4294967295 NOTICE: stop all
21:41:28 T:1680 M:4294967295 NOTICE: ES: Stopping event server
21:41:28 T:1680 M:4294967295 NOTICE: Webserver: Stopping...
21:41:28 T:1680 M:4294967295 NOTICE: WebServer: Stopped the webserver
21:41:28 T:1680 M:4294967295 NOTICE: Webserver: Stopped...
21:41:28 T:2056 M:4294967295 NOTICE: ES: UDP Event server stopped
21:41:28 T:1680 M:4294967295 NOTICE: stop sap announcement listener
21:41:28 T:1680 M:4294967295 NOTICE: clean cached files!
21:41:28 T:1680 M:4294967295 NOTICE: unload skin
21:41:28 T:1680 M:4294967295 NOTICE: stop python
21:41:28 T:1680 M:4294967295 NOTICE: stopped
21:41:28 T:1680 M:4294967295 NOTICE: destroy
21:41:28 T:1680 M:4294967295 NOTICE: unload sections
21:41:29 T:5552 M:4294967295 ERROR: CRemoteControl::Connect - failed to connect
Hope it helps.
