2013-02-10, 00:10
(2013-02-09, 20:08)richardk Wrote: [ -> ](2013-02-09, 19:59)cfetzer Wrote: [ -> ]We need to identify the component that causes this. If the frontend<->backend connections are up all the time, then reconnecting is ok.
Next suspect would be image caching.
Since I cannot reproduce this, I'd need your help. Could you please compile my branch "debug-backend-cpu"
and try that? I disabled image support in there. Let me know if that makes any difference.
(https://github.com/fetzerch/xbmc-pvr-add...nd-cpu.zip )
One more interesting thing is: How many recordings do you currently have and how often do you record?
Thanks, Christian
Thanks! I'll compile your debug version and try it. However, it could be several days before I know for sure if the problem is solved.
I have a lot of recordings -- about 1200. I record about 5-10 per day. Old recordings are deleted to make room for new ones.
Nothing definitive yet, but this is looking very promising. I built the test addon version, and installed it in my Ubuntu system (AspireRevo 1600, Ubuntu 12.10). I rebooted my MythTV system, so as to start clean there.
So far, I've played two complete one-hour HD programs, and portions of a few others. The cpu load for mythbackend has remained at about 3% - 9%, usually closer to 3% if it's not recording at the same time. This is comparable to using the MythTV frontend.
If I get energetic, I may build OpenELEC using this version of the addon. Either way, we'll keep using it, and I'll report the results here.
