2012-04-24, 19:12
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148
2012-04-24, 19:32
(2012-04-24, 10:47)Jimmer Wrote: [ -> ]Thanks for the regex, that totally works for me!
as for the cache, it contains a coverart, fanart and preview folder. All my artwork stored on the server is downloaded and present. The artwork the displays is:
Jimmer: do you have to do something special on the mythbackend to get the fanart to download? I thought that the fanart was being pulled directly by XBMC (using the information from mythbackend) using the thetvdb and themoviedb add-ons (this is how the Mythbox add-on does it, it doesn't rely on fanart supplied by mythbackend), not directly from the mythbackend. I'm using Myth 0.23.1-fixes and I couldn't find the options to get mythbackend to pull fanart/coverart. What is your setup on the myth side?
(2012-04-24, 11:17)bilbonvidia Wrote: [ -> ]at a guess this is what is going wrong when I try and watch live tv
23:02:35 T:2769161072 DEBUG: ffmpeg[A50E0B70]: [mpegts] max_analyze_duration 5000000 reached at 5000000
23:02:35 T:2769161072 DEBUG: ffmpeg[A50E0B70]: [mpegts] decoding for stream 2 failed
23:02:35 T:2769161072 DEBUG: ffmpeg[A50E0B70]: [mpegts] decoding for stream 3 failed
23:02:35 T:2769161072 DEBUG: ffmpeg[A50E0B70]: [mpegts] Could not find codec parameters (Unknown: none ([11][0][0][0] / 0x000B))
23:02:35 T:2769161072 DEBUG: ffmpeg[A50E0B70]: [mpegts] decoding for stream 4 failed
23:02:35 T:2769161072 DEBUG: ffmpeg[A50E0B70]: [mpegts] decoding for stream 5 failed
23:02:35 T:2769161072 DEBUG: ffmpeg[A50E0B70]: [mpegts] decoding for stream 6 failed
does this suggest the compile went wrong? I'll try the windows version later to see if I get similar behaviour.
Looks like live TV is having problems (see my post above) with the latest master from github, not just with myth 0.24, but also with my myth 0.23.1-fixes installation. Has anyone got live TV working successfully with any version of myth using the current github master?
2012-04-24, 20:10
I have been playing around with XBMC and the libcmyth PVR addon for Mythtv.
Mythtv is working for me (version v0.24.1-80-g1de0431) and displays the correct channels and liveTV.
However when using XBMC, I browse the LiveTV guide, it pulls down the EPG fine but then when I select a channel the working status indicator comes up and no liveTV stream is played
XBMC logs dont seem to give any hints when checking for ERROR:
http://xbmclogs.com/show.php?id=1881
XBMC is the latest git pull from https://github.com/tsp/xbmc.git.
I'm running Kbuntu 11.10 x64, kernel 3.0.0-17-server.
Not sure what the issue is and would appreciate a hand if anyone can point me in the right direction.
Cheers
Chris
03:50:14 T:139860635543296 ERROR: AddOnLog: MythTV cmyth PVR Client: LibCMyth: (cmyth)cmyth_storagegroup_update_fileinfo: QUERY_SG_FILEQUERY failed(EMPTY LIST)
03:50:14 T:139860635543296 ERROR: AddOnLog: MythTV cmyth PVR Client: LibCMyth: (cmyth)cmyth_storagegroup_get_filelist: results= 1
03:50:15 T:139860635543296 ERROR: AddOnLog: MythTV cmyth PVR Client: LibCMyth: (cmyth)cmyth_proginfo_get_detail: cmyth_proginfo_fill() failed
04:06:14 T:139860627150592 ERROR: AddOnLog: MythTV cmyth PVR Client: cleanCache, caught exception during cache cleaning
Cheers
Chris
2012-04-24, 20:15
will cmyth work on ubuntu 10.10 maverick?
or do i need to goto ubunutu 11?
2012-04-24, 20:23
Okay, I have installed the windows version and live tv is working on that BUT everything has subtitles stream enabled??
Live tv still not working on the xbmcbuntu machine.
2012-04-24, 20:37
@five:
have the following in my crontab on my backend:
uses the script supplied with mythtv for scraping metadata on your recordings. The above works for me, so it should work for you too!
Jim
PS if you don't use the options above, I think it works for mythvideo files instead of recordings... YMMV
0 5 * * * /usr/share/mythtv/mythvideo/scripts/jamu.py -l en -C "/home/mythtv/.mythtv/jamu.conf" -MW > "/tmp/jamu_watched.log"
Jim
2012-04-24, 20:37
Jimmer: Is there something special with the artwork that is not downloaded in the sql database? Does the title exactly match the first part of the artwork filename?
(2012-04-24, 03:11)fiveisalive Wrote: [ -> ]My addon only fetch the fanart/coverart from the mythbackend. It doesn't use the scrapers in XBMC (That would be nice but should go into the xbmc PVR code and not as a specific addon code). On my setup the mythfrontend seems to pull down the artwork without any user setup but that is with v0.24. Don't know about 0.23. In 0.25 the backend is responsible for pulling down the metadata so it should work better (no need to use the frontend) but I haven't stated testing 0.25 yet. I suppose it is also a requirement that the storagegroups are setup correctly.(2012-04-24, 00:48)tsp42 Wrote: [ -> ]Could you also check if there is any artwork in ~/.xbmc/userdata/addon_data/pvr.mythtv.cmyth/cache/
that are not displayed. If you have a lot of artwork it can take a while before it is transfered.
~/.xbmc/userdata/addon_data/pvr.mythtv.cmyth/cache/coverart
and
~/.xbmc/userdata/addon_data/pvr.mythtv.cmyth/cache/fanart
on my system are both empty directories. I assumed that the add-on pulled the info for each show from thetvdb or something? I haven't set any coverart or fanart in the mythbackend.
fiveisalive Wrote:Looks like live TV is having problems (see my post above) with the latest master from github, not just with myth 0.24, but also with my myth 0.23.1-fixes installation. Has anyone got live TV working successfully with any version of myth using the current github master?It works fine (obviously) on my two systems (windows 7/Mythbuntu 11.04).
chrisgibbs Wrote:However when using XBMC, I browse the LiveTV guide, it pulls down the EPG fine but then when I select a channel the working status indicator comes up and no liveTV stream is playedLooks like the storage group is not setup properly on the backend. Shouldn't affect the LiveTV though. Could you pastebin a log with the "Include more debug information in the Log" enabled?
bilbonvidia Wrote:at a guess this is what is going wrong when I try and watch live tvLooks like a problem with ffmpeg. There were some changes in the ffmpeg code with the lastest upstream pull. Did you compile from a freshly cloned source code? Does recorded programs work and is it the same with all channels (HD/non HD).
2012-04-24, 20:38
(2012-04-24, 20:15)darkwizard Wrote: [ -> ]will cmyth work on ubuntu 10.10 maverick?
I had it working just fine on maverick until a few weeks ago. As long as you have all the right dependencies installed, it should build. And if it builds, it should run....
2012-04-24, 20:58
@tsp42
Yes complete xbmcbuntu re-install yesterday and git pull. Same for all channels, the recordings play okay but they have subtitles in as does live tv on the windows machine. Is that a backend thing??
Quote:Looks like a problem with ffmpeg. There were some changes in the ffmpeg code with the lastest upstream pull. Did you compile from a freshly cloned source code? Does recorded programs work and is it the same with all channels (HD/non HD).
2012-04-24, 21:08
(2012-04-24, 20:58)bilbonvidia Wrote: [ -> ]Yes complete xbmcbuntu re-install yesterday and git pull. Same for all channels, the recordings play okay but they have subtitles in as does live tv on the windows machine. Is that a backend thing??No that is xbmc's fault. The backend just delivers the file with no control on how it is decoded and displayed. I will soon have to backport my changes to eden stable PVR. Maybe you could try compiling against an external ffmpeg library on ubuntu?
2012-04-24, 21:09
i get this error
cppmyth/MythEventHandler.cpp:55: warning: âMythEventHandler::ImpMythEventHandler::m_conn_tâ will be initialized after
cppmyth/MythEventHandler.cpp:62: warning: base âPLATFORM::CThreadâ
cppmyth/MythEventHandler.cpp:61: warning: when initialized here
cppmyth/MythEventHandler.cpp:50: warning: âMythEventHandler::ImpMythEventHandler::m_signalâ will be initialized after
cppmyth/MythEventHandler.cpp:62: warning: base âPLATFORM::CMutexâ
CPP xbmc/pvrclients/mythtv-cmyth/cppmyth/MythFile.o
CPP xbmc/pvrclients/mythtv-cmyth/cppmyth/MythProgramInfo.o
CPP xbmc/pvrclients/mythtv-cmyth/cppmyth/MythRecorder.o
CPP xbmc/pvrclients/mythtv-cmyth/cppmyth/MythSignal.o
CPP xbmc/pvrclients/mythtv-cmyth/cppmyth/MythTimer.o
CPP xbmc/pvrclients/mythtv-cmyth/cppmyth/MythTimestamp.o
CPP xbmc/pvrclients/mythtv-cmyth/cppmyth/MythSGFile.o
CPP xbmc/pvrclients/mythtv-cmyth/fileOps.o
fileOps.h: In constructor âfileOps2::fileOps2(MythConnection&)â:
fileOps.h:53: warning: âfileOps2::m_conâ will be initialized after
fileOps.h:52: warning: âboost::filesystem::path fileOps2::m_localBasePathâ
fileOps.cpp:16: warning: when initialized here
fileOps.h:54: warning: âfileOps2::m_sg_stringsâ will be initialized after
fileOps.cpp:17: warning: base âPLATFORM::CThreadâ
fileOps.cpp:21: error: âstruct boost::filesystem::pathâ has no member named âc_strâ
fileOps.cpp: In member function âCStdString fileOps2::getChannelIconPath(CStdString)â:
fileOps.cpp:42: error: âstruct std::basic_string<char, std::char_traits<char>, std::allocator<char> >â has no member named âstringâ
fileOps.cpp: In member function âCStdString fileOps2::getPreviewIconPath(CStdString)â:
fileOps.cpp:63: error: âstruct std::basic_string<char, std::char_traits<char>, std::allocator<char> >â has no member named âstringâ
fileOps.cpp: In member function âCStdString fileOps2::getArtworkPath(CStdString, FILE_OPTIONS)â:
fileOps.cpp:95: error: âstruct std::basic_string<char, std::char_traits<char>, std::allocator<char> >â has no member named âstringâ
fileOps.cpp: In member function âvoid fileOps2::cleanCache()â:
fileOps.cpp:142: error: âstruct std::basic_string<char, std::char_traits<char>, std::allocator<char> >â has no member named âstringâ
fileOps.cpp:151: warning: comparison between signed and unsigned integer expressions
fileOps.cpp:150: warning: unused variable âmlmâ
fileOps.cpp: In member function âbool fileOps2::writeFile(boost::filesystem::path, MythFile&)â:
fileOps.cpp:240: error: âstruct boost::filesystem::basic_path<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, boost::filesystem::path_traits>â has no member named âc_strâ
fileOps.cpp:246: error: âstruct boost::filesystem::basic_path<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, boost::filesystem::path_traits>â has no member named âc_strâ
fileOps.cpp:294: error: âstruct boost::filesystem::pathâ has no member named âc_strâ
make[1]: *** [fileOps.o] Error 1
make[1]: Leaving directory `/root/src/xbmc/xbmc/pvrclients/mythtv-cmyth'
make: *** [pvrclients] Error 2
(2012-04-24, 20:38)Jimmer Wrote: [ -> ](2012-04-24, 20:15)darkwizard Wrote: [ -> ]will cmyth work on ubuntu 10.10 maverick?
2012-04-24, 21:26
got it to compile but it says xbmc 12.0-alpha1... now when i configure mythtv addon it just says mythtv backend hostname or ip and mythxml port nothing else
and i set it all up then hit livetv channels it says no pvr client started yet..
so i goto system info and pvr client it all blank.?
did i do something wrong
ps running mythtv 24
2012-04-24, 21:35
darkwizard:
Sounds like you are using the wrong addon. It is called mythtv-cmyth not mythtv.
2012-04-24, 21:40
(2012-04-24, 21:26)darkwizard Wrote: [ -> ]got it to compile but it says xbmc 12.0-alpha1... now when i configure mythtv addon it just says mythtv backend hostname or ip and mythxml port nothing else
I think your earlier compile issue was you needed to install the lboost libraries as I did earlier in the thread. There are two myth tv addons you need to enable the cmyth addon,
2012-04-24, 21:50
were cmyth addon at?
