janbar
I tried increasing the duration of usleep to 999999 up from 500000. Still seems to do the same thing.
dst6se
Good to see I am not the only one with this issue anymore. This has been an issue for some weeks now but I hope janbar will come up with a solution soon. There are so many new features I would like to try but I cant seem to get playback to start reliably which is a showstopper for me.
(2012-10-30, 07:28)Aubrien Wrote: [ -> ]@janbar
@dst6se
I have also tried all the different fixes but it still stop after a couple of sec , i tried both mythbackend 0.25, 0.26.
(2012-10-30, 11:46)dst6se Wrote: [ -> ] (2012-10-30, 07:28)Aubrien Wrote: [ -> ]@janbar
@dst6se
I am going slowly, but i updated ago the mythtv code to track the issue directly in the backend. I will tell you what happens. By chance i have always a channel doing sometime the issue.
(2012-10-30, 21:31)janbar Wrote: [ -> ] (2012-10-30, 11:46)dst6se Wrote: [ -> ] (2012-10-30, 07:28)Aubrien Wrote: [ -> ]@janbar
@dst6se
If you need some help, with logs feel free to ask !!
Thanks for all the work !
Thanks Janbar. Your hard work is appreciated.
(2012-10-31, 01:32)Aubrien Wrote: [ -> ]Thanks Janbar. Your hard work is appreciated.
Aubrien
Have you tried with mythbackend v0.24 ??
Hi guys,
i'm building the addons on maverick following this guide.
http://wiki.xbmc.org/index.php?title=PVR...FromSource
the addon builds, however, when i enable livetv xbmc just dies. with this:
17:03:39 T:3002067824 NOTICE: Thread PVR manager start, auto delete: false
17:03:39 T:3020864368 DEBUG: Thread EPG updater 3020864368 terminating
17:03:39 T:3020864368 NOTICE: Thread PVR add-on updater start, auto delete: false
17:03:39 T:3020864368 DEBUG: PVR - ResetProperties - creating PVR add-on instance 'MythTV cmyth PVR Client'
17:03:39 T:3020864368 DEBUG: InitialiseClient - initialising add-on 'MythTV cmyth PVR Client'
17:03:39 T:3020864368 DEBUG: ADDON: Dll Initializing - MythTV cmyth PVR Client
17:03:39 T:3020864368 DEBUG: SECTION:LoadDLL(/home/sandal/.xbmc/addons/pvr.mythtv.cmyth/XBMC_MythTV_cmyth.pvr)
17:03:39 T:3020864368 DEBUG: Loading: /home/sandal/.xbmc/addons/pvr.mythtv.cmyth/XBMC_MythTV_cmyth.pvr
Any clues?
(2012-10-31, 19:19)dubstar_04 Wrote: [ -> ]Hi guys,
Any clues?
So far this looks good, is there more output afterwards?
Did you build it on the same system? Any suspicious warnings during build?
Maybe it could help if you pastebin the full build/and debug log.
Cheers, Christian
(2012-10-30, 22:00)dst6se Wrote: [ -> ] (2012-10-30, 21:31)janbar Wrote: [ -> ] (2012-10-30, 11:46)dst6se Wrote: [ -> ]I have also tried all the different fixes but it still stop after a couple of sec , i tried both mythbackend 0.25, 0.26.
I found something: Mythtv stop to send the stream when requested block is to big compared to input stream. So it stop playback. Now i can reproduce the stuff by overloading my storage. I am thinking to update the code to manage this situation by reduce the request size depending of returned size of previous block. Also when channel tune is bad many frames are dropped and stream flow become small and then the request size should be small too. Think in this case the spawn and switch channel could be longer.
(2012-10-31, 22:45)janbar Wrote: [ -> ] (2012-10-30, 22:00)dst6se Wrote: [ -> ] (2012-10-30, 21:31)janbar Wrote: [ -> ]I am going slowly, but i updated ago the mythtv code to track the issue directly in the backend. I will tell you what happens. By chance i have always a channel doing sometime the issue.
Great, that explans why i never had any problems on my HD channels !
Is it safe to upgrade to MythTV v0.26 yet? I've held back upgrading from Ubuntu 12.04 to 12.10 because I don't know how the support for v0.26 compares to v0.25.
i'm running 0.26 fine for a few weeks now and i haven't found any problems, i don't use it for live tv though so not tested much.
I think I am misunderstanding something here.
I have been following the instructions at
and have built successfully the pvr.mythtv.cmyth addon.
But when I try to load it into my OpenElec system I get:
07:07:02 T:139799709087488 ERROR: Unable to load /storage/.xbmc/addons/pvr.mythtv.cmyth/XBMC_MythTV_cmyth.pvr, reason: libmysqlclient.so.18: cannot open shared object file: No such file or directory
It was compiled with --enable-addons-with-dependencies
but no where can I see instructions that indicate how to get mysql library into OpenElec.
OpenElec latest build version:
16:40:15 T:139800273803072 NOTICE: Starting XBMC (12.0-ALPHA7 Git:1677554), Platform: Linux (OpenELEC - Version: devel-20121029172525-r12322, 3.6.3 x86_64). Built on Oct 29 2012
Can anyone help?
Problem is that you need the mysql runtime library.
Checkout if this post helps:
http://openelec.tv/forum/71-pvr--live-tv...t=20#51641
I guess it's this line that is missing in your build config:
PKG_DEPENDS="mysql curl"
If you get it running, could you update the build wiki?
BTW: Does it work for anybody on the rPI?
Cheers, Christian
pgjensen
I haven't switched my primary MythTV backend to 0.26 yet, but I've been running a test server in parallel. I would say 0.26 is similar to slightly better. I seem to have fewer instances of live video stopping or refusing to start and things feel a bit more stable. I use HD-PVRs and an ATSC HDHomerun as inputs. Both servers run Ubuntu 12.04.
Last time I checked, XBMC nightlies had not been updated to allow myth:// protocol to work with 0.26, but it's unneeded now that janbar and cfetzer are providing this great add-on.
Jerry
