2011-09-22, 00:18
Up until recently, connecting to shared folders over the network was working fine for me. But recently, every time I try to add an SMB source, the list is empty (i.e. I can't see any of my shared folders). Oddly, I can map a network drive and add the source that way, but since I'm trying to set this up with my AppleTV, I'm assuming (?) this won't work for what I'm trying to do.
Here's a checklist of things I've ensured:
- All of the networked computers are in the same workgroup
- File and printer sharing is enabled
- Password protected sharing is disabled
- The folders are obviously being shared because I can access them through Windows Explorer
- I haven't changed any router settings
The problem started when I was moving my external media drives to another computer on the network to act as a media server of sorts. I did name some of the Shared folders the same as they had been shared on the previous computer, but I have since returned to the original setup so I'm not sure if/why this would still be a problem.
I've uploaded my log file here: http://pastebin.com/mD6CMVRj
I'm guessing the issue is the following line, but I'm not sure what to make of it:
Using 10.1 on my Windows XBMC and I've used both the most recent stable version (?) on AppleTV in addition to a nightly build (20110919 I believe). I don't believe it's a platform-specific issue. (Edit: Also, this is occurring on two of my Windows machines and the AppleTV, so it seems to be network-wide)
If anyone has an idea, I would greatly appreciate the help. I've exhausted most of my ideas after days of searching.
18:02:26 T:4548 M:2608562176 ERROR: WnetOpenEnum failed with error 1222
