Full Version: [ATV2] TuxBox stream no longer works
hi
i have updatedto a nightly from 19. sept and now i can not stream from tuxbox.
Video and audio stutters.
it is not a network bandwith problem, because samba streaming works, and with the stable release it works also.
here es the xbmc log..
CGUIInfoManager::SetCurrentMovie(http://192.168.1.140:8001/1:0:1:32D4:45D:1:C00000:0:0:0:)
05:39:04 T:72605696   DEBUG: GetMovieId (http://192.168.1.140:8001/1:0:1:32D4:45D:1:C00000:0:0:0:), query = select idMovie from movie where idFile=6821
05:39:04 T:72605696   DEBUG: GetEpisodeId (http://192.168.1.140:8001/1:0:1:32D4:45D:1:C00000:0:0:0:), query = select idEpisode from episode where idFile=6821
05:39:04 T:72605696   DEBUG: GetMusicVideoId (http://192.168.1.140:8001/1:0:1:32D4:45D:1:C00000:0:0:0:), query = select idMVideo from musicvideo where idFile=6821
05:39:04 T:72605696   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
05:39:04 T:72605696   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
05:39:04 T:72605696   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
05:39:08 T:72605696    INFO: CheckIdle - Closing session to http://feeds.feedburner.com (easy=0x5e6a000, multi=0x1f9b5980)
05:39:10 T:72605696    INFO: CheckIdle - Closing session to http://xoap.weather.com (easy=0x5322000, multi=0x1f87ba10)
05:39:10 T:105906176   DEBUG: CDVDPlayer::SetCaching - caching state 3
05:39:10 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:3056581.152777, should be:2751844.444234, error:-304736.708543
05:39:10 T:105906176   DEBUG: CDVDPlayer::SetCaching - caching state 0
05:39:11 T:72605696   DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
05:39:12 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:4065387.569234, should be:4111042.908530, error:45655.339296
05:39:13 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:5247812.741863, should be:4887822.444444, error:-359990.297419
05:39:14 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:6261465.986111, should be:6244310.795198, error:-17155.190912
05:39:16 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:8369290.545198, should be:8247822.444445, error:-121468.100754
05:39:16 T:72605696   DEBUG: ------ Window Init (VideoOSD.xml) ------
05:39:16 T:72605696    INFO: Loading skin file: VideoOSD.xml
05:39:17 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:8749153.236111, should be:8607822.444445, error:-141330.791666
05:39:17 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:9102916.736112, should be:8919822.444443, error:-183094.291669
05:39:18 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:9411814.027777, should be:9231822.444445, error:-179991.583332
05:39:18 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:9877817.986112, should be:9759822.444443, error:-117995.541668
05:39:19 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:10375382.944443, should be:10095889.902569, error:-279493.041875
05:39:20 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:10581303.360902, should be:10431822.444446, error:-149480.916456
05:39:21 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:11435391.861112, should be:11247888.485904, error:-187503.375208
05:39:21 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:11748372.527570, should be:11583822.444444, error:-164550.083127
05:39:22 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:12846212.152777, should be:12615822.444443, error:-230389.708334
05:39:23 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:13132065.611110, should be:12951822.444446, error:-180243.166664
05:39:23 T:121335808   DEBUG: CDVDPlayerAudio:: Discontinuity - was:13436469.944446, should be:13287822.444445
mayby someone has a solution.
greetz muggi
Post full log to pastebin and post link here.
Ned Scott Wrote:Post full log to pastebin and post link here.
Hi Ned,
here is the link:
http://pastebin.com/WZvAgmj2
muggi Wrote:Hi Ned,
here is the link:
Is this happening for all channels that you try to stream? I'm using the 20110921 without issue, on the whole. Not using the Tuxbox functionality as such due to URL encoding issues, and am instead using a modified version of plugin.video.dreambox instead.
Try that build anyway and report back, as it could be that something was broken on the 19th with the MPEG2 audio.
Are you using an Enigma1 or Enigma2 based box? Seems to be Enigma2.
hi slain
it happens with all cannels.
But even with my smb server the audio stutters. it is no network issue, because my living room xbmc install works good.
I will re-jailbreak the atv2 and start from the begin and hope you can post your modded dreambox plugin today....
hi
after a day of trying i think it is hardware problem of the atv.....
Hi
With annother ATV this is also the Same issue.
Same Error in log... Any adviceHuh
hi
i´ve updated to the nighlty from 26/9 and it is the same issue.
But i have found the issue.
If i turn the deinterlaced mode to off, the mpeg2 - tuxbox stream does not
stutter and run fine.
Oh man, I should have thought of that. Around the 19th is when the interlacing overhaul was being done. Sorry we weren't of much help, but glad it was resolved!
muggi Wrote:hi
but if you want to deinterlace sd content there is now the software blend method back in which can be handled by atv2 ...
hello,
i had the same problem with livestreaming from dreambox,
thx for the solution,it rans now pretty good Big Grin
(nighltybuild from 21.09.11)
regards
Can somebody help me with this please?
I've read this:
http://wiki.xbmc.org/index.php?title=TuxBox
Repeatedly, but still don't get how to set this up.
Is there a basic how to guide? Do I have to do something on the dreambox? (a DM800 running an Enigma 2 image).
Scrap that, got the basics now I think.
I now have a share on xbmc on atv2 as tuxbox, it brings up my bouquets, but not the stream, when I select a channel nothing happens.
FoxForceFive Wrote:Scrap that, got the basics now I think.
You have the same issue as me. I've posted this in another thread as well, but may as well cross-post for impact. Need to know if it fixes the issue for those that can't stream from channels with whitespace in the channel name.
plugin.video.dreambox v1.0.2 by Flatman/slain
http://www.hardc0re.org.uk/xbmc-plugin_v...0.2.tar.gz
Here is a german description of what you must adjust:
http://www.chrisz.de/?p=840
hope its helps.
regards
