Sometimes my XBMC is chaotically running through the categories and no any way to stop it, only by pressing restart button on my PC-Box.
Did anyone faced this phenomena?
Cat sat on your keyboard?
not using keyboard, activating via Samsung Galaxy
jhsrennie Wrote:Presumably using the XBMC remote control app?
I use the official XBMC remote, https://market.android.com/details?id=or...oid.remote, and I've never seen the problem you describe.
JR
Had this problem once. Don't use the app very often.
Also with the official xbmc remote app for Android. It was while rapidly browsing trough the library. It just went nuts. Could stop it bij hitting a key but after key release it just continued.
Using HTC Sense and pre-eden
I had this happen last night (I think its what you are talking of). All of a sudden the MUTE and vol kept flashing on/off real quick (as if a button was stuck) but there was nothing around. I use a key mapper to control XBMC and the remote was just sitting on the couch doing nothing.
I couldn't stop it so had to press my "reset all software" button on the remote and all was fine after that.
