Full Version: Jerk on two movies, only in XBMC
Pages: 1 2
I have a problem with somes movies, the bourne trilogy & LOTR extended, both in 1080p released. The video is slightly jerky.
My system :
- Mac OS X SL
- XBMC up to date
- Mac mini 2010 CD2 2,4 Ghz / 8 Go
- LOEWE Individual Selection 40 DR+
First i thought it was the files, the encoding, but it play well on MplayerX, VLC...
I guy suggested me to activate the video/sound synchronization but a quick test show no effect.
Any idea ?
xbmc.log and mediainfo on the suspect files. that's the drill, it's in the faq about reporting problems. Otherwise... no soup Smile
Ok, i'll post my Log and the result of mediainfo Smile
How can i upload the XBMC.log & the result of Mediainfo ?
pastebin it then post link here
Thanks,
Don't know exactly how it works so here is the XBMC log:
http://pastebin.com/raw.php?i=xQsNZNFr
Here is the media log:
http://pastebin.com/raw.php?i=Bmt6wLqm
Any idea ?
UP
Up
Each time you bump the thread is another time I ignore this thread and pass it by on my forum cycle.
davilla Wrote:Each time you bump the thread is another time I ignore this thread and pass it by on my forum cycle.
Thank you for the information, I can not follow the logic, since I posted the files in response to your advice. Now i should let die my request for assitance on this same advice?
I think it would be easier to be clear in your messages, you or someone else can help me and agrees to do so or not, I used to spend time on a lot of forums and this the first time i read such an answer.
Have a nice week end.
turn on debug logging and repost
Debug logging is turned on, the problem is there aren't any audio packets coming in.
cut a 50-100MB sample that shows the same problem and dropbox it.
Pages: 1 2
