That's amazing!.. can't wait to try this one out!!! :-)
Great work MarcosQui!
I have been using the MQ2 for a while and yesterday I tried MQ3. I felt it went smoother, but I´m having some issues on using on my amd fusion htpc with the new skin. Whenever I go into any of the menus like movies or videos it just get black, tried as well different kind of viewtype and that didnt help. But I can go back to the head of the menu using ESC.
Anyone else experiencing the same thing? Downloaded the skin from the repo.
Dharma's version is only available in zip format for now, the version that is in the repo is Eden.
In the first message of this topic I explain the details, please, read it again = 'HOW TO GET THE SKIN'
Some of the addons (like Artwork organiser) are Eden only
And I'm running XBMC Live, which doesn't get nightlies
I'm sad now
I had not realized this, I'll have to replace the add-on to version Dharma.
If you could maybe provide download links to Dharma versions of the addons, that would be really awesome
I've had trouble tracking them all down (those that support Dharma).
Sure, I'll ask to Wanilton, he takes care of that.
business as usual... :-)...
Honestly, again a masterpiece marcos...thanks for this...
cheers,
mm
PS: if you need something, just gimme a hit...
Sorry, I have a quick question. When I go to the Movies or TV Shows options, I am first presented with a list including:
Movies
TV Shows
Recently Added Movies
Recently Added Episodes
Playlists
Video Add-Ons
Instead of going straight to Movies or TV shows, I get this list, which looks to me like the parent VIDEOS menu.
Is there a way to go directly into Movies and TV Shows without seeing this list?
May I also make a suggestion?
I'd love it if there could be an icon for UNWATCHED films and tv shows instead of WATCHED, because I have watched most of my content so I have a library full of little green watched ticks. I'd much prefer it if there was a NEW icon instead of the watched tick.
Rumik Wrote:Sorry, I have a quick question. When I go to the Movies or TV Shows options, I am first presented with a list including:
Movies
TV Shows
Playlists
Video Add-Ons
If you created the collection correctly and are using the correct version of the skin to the corresponding version of XBMC, everything should work fine.
mad-max Wrote:business as usual... :-)...
cheers,
mm
Thanks for all your great help.
Also, is the TV guide going to be making a comeback?
