Full Version: [RELEASE] XBMC-ECP (eMule Control Panel) Script
Pages: 1 2 3 4 5 6
wow  :thumbsup:
new logo screenshot
release in cvs 13/04/2005
new feature:
- new xbmc-emule control panel logo, thanks lolol!!
- dialog progress "connection to 192.169.3.44..."
- file details: you can see details of previous and next file with up and down keys
- search list: when starting to download something set "<ok>" in right column
- search dialog: new button "clear"
- search dialog: remember last search (saved in config file)
- setting menu: new item "controller" with help on controller buttons
update:
- context menu: new style with buttons instead on controllist and new background
- file details: new style with controltext instead of controllist and new background
- settings menu: use new contextmenu
bugfix:
- small bug if you change password in emule next connection "wrong password" then wizard but after wizard can't yet connect
- decode name and file info (new subroutine "decode") "&amp -> 6,  \\ -> \"
Quote:does it run with any version of emule including a webserver?
no, i use only emuleplus... if someone need i can try to create other templates... :d
Quote:i run morph xt 6.4 i dont want to change that...
you are asking me so i'm trying to do that...   :lol:
hi,
i think we really need a emulexml.tmpl for emule (the standard from http://www.emule-project.net).
90% of all people use this one...
seems also very similar to morph  :thumbsup:
(sambarza @ april 14 2005,09:38 Wrote:you are asking me so i'm trying to do that... :lol:
hi,
sorry here come the => pleeeeeeeaaaaaaaasssssssseeeeeee <=
ps: i would love to use it with emule too...
i'm rewriting the module for connection to emule... more general... with plugins
hi,
great i am really looking forward for it....
yeah!
good news....
with a better compatibility to other emule clients, emule-ecp would be a "must-have"-script for xbmc users running emule.
cu lolol
:bomb:  :nuts:  :nuts:
i was getting crazy!
have you ever seen this message? every time you try to run a script?
systemerror: null result without error in pyobject
i can't run xbmc-ecp for hours before understand!!!
all script files on xbox was with date  9 may 2004... soo reboot orig dash, it ask me for date and time (why?? a physical reset of bios??) then copied script on xbox again..
now is ok  Huh
do you this problem?
ok.... first release with new plugin structure
i tested it with:
emule
emuleplus
morphxt v6.7
play with it and let me know:
new plugin version   :d
hi,
runs good but i can´t see anything in my download range...
i need some info :
- emule version
- language in emule
- template you are using
- xbmc version
- server status is ok (bottom left on main screen)?
- upload list is ok?
- there are messages in script log?
thanks
hi,
- emule version
0.45b
- language in emule
german
emulexml.tmpl
- xbmc version
cvs build from yesterday
will check this later
yes
19-04-2005 17:36:28 info file "q:\scripts\emuleconnector\emuleconnector.py", line 171, in get_download_list
19-04-2005 17:36:28 info l_list = self.plugin.get_download_list()
19-04-2005 17:36:28 info file "q:\scripts\emuleconnector\plugins\emule.py", line 116, in get_download_list
19-04-2005 17:36:28 info info = util.decode(info)
19-04-2005 17:36:28 info file "q:\scripts\emuleconnector\util.py", line 57, in decode
19-04-2005 17:36:28 info new_text = new_text.replace("\\\\", u"\u005c")
19-04-2005 17:36:28 info unicodedecodeerror: 'ascii' codec can't decode byte 0xc3 in position 74: ordinal not in range(128)
19-04-2005 17:36:28 info activating window id: 13000
Pages: 1 2 3 4 5 6
