hi,
i switched my language from german to english and now it runs fine :-) i think its a problem with the special german characters as ä ö ü
there was a problem on encoding of filenames...
i make some changes on templates and script but also a patch is necessary in xbmc...
when patch is ready i release everything...
however this a fast patch to resolve...
:d
replace file util.py with this:
fix util.py
hi,
good work but i will stay with english language...
:kickass:
hi,
you can have some problems also with english language... depends from filename.... as you want... :talktohand:
hi,
okay okay you got the point i will install your patch !
:pirate: i sam!!!
very cool idea!
:idea:
unfortunately i cannot help u in your work :verysad:
now u are quite new in phyton but just for a while.. :lol:
u are a great programmer and i can imagine u'll become a guru in a very few period of time in phyton too :bowdown:
see u friend
wow... what are you doing here?? :lol:
yes i'm very new to python...
Quote:u are a great programmer and i can imagine u'll become a guru in a very few period of time in phyton too
ehehehe i don't think that :p
yes i can help you on what we know..... if i can...
working on tweaking for pm3 (moving around mainly) at any rate here is where that stands
opinions are always welcome
main
info
goooddd
you have 16:9.... correct? in 4:3 mainlist is a bit small...
good :d
in next release:
- fixed unicode bug
- open files from download list (location mapping eg."e:\emule_incoming\" -> "xns://192168.1.10...")
- pause, restart download
what you need also? nothing? good ! :p
(harshreality @ april 25 2005,11:12 Wrote:working on tweaking for pm3 (moving around mainly) at any rate here is where that stands
main
info
hi,
great skin => go on !
harshreality i can set in code (if skin is 'pm3')...
can you send the changes?
is there any way someone could do a similar thing for abc? we have a couple of scripts now that let us add torrents, but none that allow us to use the other aspects of the web-service. i can't do it myself (i don't know how), but i think it would be great! :thumbsup:
sambarraza, got the movements figured out will send files as soon as i rip them off my box. been doing it to about every script i can get (done 7 so far to cut back on graphics and clutter) so they use background-apps.png (is in the textures file, most default for script displays)
tomkun, there is a torrentbrowser3 on xbmcscripts.com that allows you to config for abc (i myself use azureus so i am hoping for one for it
