Full Version: [RELEASE] XBMC-ECP (eMule Control Panel) Script
Pages: 1 2 3 4 5 6
thanks harshreality.... in next release :d
welcome, glad to be of help Smile
(harshreality @ april 25 2005,13:00 Wrote:tomkun, there is a torrentbrowser3 on xbmcscripts.com that allows you to config for abc
yeah, i know about that and i use it all the time. although, all it allows you to do is add files to abc. i would love it if i could see download progress etc... on my xbox.
(sambarza @ april 25 2005,13:22 Wrote:thanks harshreality.... in next release :d
lo sambarza, thanks a lot for your script
did u release a new one today ?
next release date will be 29.04.2005... tomorrow evening...
hello
thx for this script :p
but i have some troubles ... i use emle 0.46c and when i want to put emule.xml i get error message so i try with emuleplus.xml ... i also try english language in emule ....
in xbmc i show upload list but don't see download ... :/
i see no post from 04/2005 may this project was end ? ..
thx
french user try to write english :§
hi,
i'm here only for problems...
which version of ecp are you using? (where you get it?)
ciao
sam
yup
i use last build found at source forge 17-04-2005
and when i put emuleplusxml.tmpl in log i have this messages :
23/08/2005 01:10:25: can't load templates: can't open file tmpl_kaddlg
23/08/2005 01:10:25: can't load templates: can't open file tmpl_bootstrapline
23/08/2005 01:10:25: can't load templates: can't open file tmpl_myinfo
23/08/2005 01:10:25: can't load templates: can't open file tmpl_commentlist
23/08/2005 01:10:25: can't load templates: can't open file tmpl_commentlist_line
thx for support ^^
hi,
for emule you need emule.tmpl template, this is a must
i think the problem on download list is a unicode ploblem resolved in cvs... mmmh...
i'm preparing a new package from cvs version...
staytuned
ciao
sam
yup
i can't use emulexml.tmpl cause i have this message :
so only emuleplusxml.tmpl don't show error ... :/
thx for support again, i hope for next version
can you make a background image in your script ? cause with pmiii default background is not fine to read listing :p
bye
re
i found ! .. i use category and my first is "all" when i filtered by download (so i show only download) in xbmc i show download list ^^ also i use default language (english)
i also find path background :p
so good it's ok now !!!!
thx
hi!
you did a great job!
but it doesn't seems to works with emule 0.46c. there should be a problem in the script i have to charge the emuleplus one.
there is a fix or workaround?
i can search, show upload, but download list doesn't work.
thx
ok for real ... :p
in emule must show download and upload (no only download or upload) ... and now work all the time :p
for unicode = english language
category = for all filtered downloading
that all ^^
Quote:but it doesn't seems to works with emule 0.46c. there should be a problem in the script i have to charge the emuleplus one.
wow emule from release 0.46c started with a new template like emule+
from emule change log:
merged webinterface from emule+, adapted, did some fixes and added: kad-window, show comments & ratings download of completed files via browser (up to 5mb filesize)]
i'm upgrading from 0.45b to 0.46c will tell you...  :thumbsup:
hi,
unicode problem is linked to the name of the files your are downloading not in the language of the gui
i'm making somechanges before new release:
- unicode
- plugin and template for emule 0.46c (problem for download filter and server connection)
- skinnable interface
- skin for pmiii - harshreality version :-)
- start complete files directly from the host (via smb or xns)
soon guys :-)
Pages: 1 2 3 4 5 6
