hey.
so i got another little problem:
i just updated to the latest version to use functions like
LatestMovie.1.Path and System.Date(dd. MMM)
These functions work now, but the submenu doesnt.
My button has <onright>1010</onright> and the container looks similar to this:
<control type="group" id="1010">
<animation effect="fade" start="100" end="0" delay="0" time="100" condition="!ControlGroup(1010).HasFocus">conditional</animation>
<animation effect="fade" start="0" end="100" delay="100" time="100" condition="ControlGroup(1010).HasFocus">conditional</animation>
<control type="grouplist" id="1011">
In the stable build it works...any1 got an idea?
Try <onright>Setfocus(1010)</onright>.
conehead Wrote:In the stable build it works...any1 got an idea?
Problem being it's not visible or it does not get focus?
Hitcher Wrote:Try <onright>Setfocus(1010)</onright>.
Doesn't work either, but at least my Videos button doesn't seem to have the focus anymore.
pecinko Wrote:Problem being it's not visible or it does not get focus?
It's not even visible.
The grouplist has in it:
<visible>Control(1010).HasFocus(1)</visible>
And my other buttons should move, as soon as 1010 has the focus:
<animation effect="slide" end="0,40" time="100" condition="Control.HasFocus(1010)">conditional</animation>
But they dont move either
<visible allowhiddenfocus="true">
now the other buttons do their animation.
but my submenu is still not visible.
hmm here is all my code of my submenu:
<posx>0</posx>
<posy>120</posy>
<width>1280</width>
<height>40</height>
<align>center</align>
<orientation>horizontal</orientation>
<onup>1001</onup>
<ondown>1001</ondown>
<itemgap>0</itemgap>
<visible allowhiddenfocus="true">Control(1010).HasFocus(1)</visible>
<control type="button" id="10111">
<include>submenubar</include>
<label>Movies</label>
<onclick>ActivateWindow(Settings)</onclick>
</control>
<control type="button" id="10112">
<label>Series</label>
<onclick>ActivateWindow(AddonBrowser)</onclick>
</control>
<control type="button" id="10113">
<label>Recently Added</label>
</control>
<control type="button" id="10114">
<label>Files</label>
</control>
</control>
</control>
the include:
<include name="submenubar">
<font>S</font>
<textcolor>FFdefb18</textcolor>
<disabledcolor>FFdefb18</disabledcolor>
<focusedcolor>FFFFFFFF</focusedcolor>
<texturefocus></texturefocus>
<texturenofocus></texturenofocus>
</include>
and "videos" give the focus to 1010. this works, because i can see the other buttons moving. just still not visible.
but already thanks for your help!
Try this:
<animation effect="fade" start="100" end="0" time="0" condition="!Control.HasFocus(1011)">conditional</animation>
<posx>0</posx>
<posy>120</posy>
<width>1280</width>
<height>40</height>
<onup>1001</onup>
</control>
</control>
</control>
</control>
</control>
</control>
Don't recall if a grouplist is a groupcontrol or single control, but this construction should definitely work, I use it for my submenus.
Big_Noid Wrote:Don't recall if a grouplist is a groupcontrol or single control, but this construction should definitely work, I use it for my submenus.
you use the latest version?
as i said, here it worked with the stable, too.
but now its not working anymore. :/
Yeah, latest build. Oh and your onright should be 1011 instead of 1010 in this construction.
Do you really need id=1010 for group?
hmm i cant find any mistake.
and yes a grouplist is a controlgroup. works with the animation effects.
i even tried to put an image into the group and set the x and y positions...still nothing to see.
hmm and i tried it your way, but its just not working.
okay i got it working.
i had to remove this:
<visible allowhiddenfocus="true">Control(1010).HasFocus</visible>
strange :/
but now it works as it should.
thx to all helpers
