I just installed the newest version on PM3 HD and I wanted to change the menu backgrounds and the only menu I can not change is Movies. I can go through and select the picture and when I hit ok it stays as the default picture
Thank you. I was begining to wonder if i was going nuts. Im still new to the xbmc htpc thing. and out of all the skins this is the easiest and prettiest for a nublet to use. everything is straight forward. thank you
Jezz_X Wrote:You are correct its a bug that I fixed today in my github source https://github.com/JezzX/skin.pm3-hd/com...8925e1351e
basically skin settings was setting the wrong variable
Home_Custom_Back_Movie_Folder
instead of
Home_Custom_Back_Movies_Folder
Im also new to this, Im having the same problem with background....BTW love the skin....so how do I fix this with the xml.
bckane Wrote:Im also new to this, Im having the same problem with background....BTW love the skin....so how do I fix this with the xml.
If you click on the link I posted above it will tell you exactly including the line numbers to edit
btw its (720p/custom_SkinSetting_1111.xml)
Jezz_X Wrote:If you click on the link I posted above it will tell you exactly including the line numbers to edit
I got it thanks.......
I just copied the whole xml file and replaced with old one seem to be working great
