2011-09-29, 14:18
Ok peeps. I've been looking through hundreds of posts and nothing has worked for me so far. I have a simple setup. Ubuntu 11.04, XBMC PRE-11.0 (Sep 28 2011), an ASRock ION330 and an Onkyo SR-507 or something like that.
What do I have to do to get audio working over HDMI? I've unmuted the SPDIF's through the alsamixer command (only mic and line are muted). I've set the following settings in XBMC:
Audio Output: HDMI
Speaker Configuration: 5.1
Dolby Digital Capable: yes
DTS capable: yes
Audio Output Device: hdmi (ALSA)
Passtrough Output Device: hdmi (ALSA)
In Ubutu the sound work properly. In XBMC it constantly says 'Failed to initialize audio device".
I replaced some configuration files from ALSA.
sudo wget http://pastebin.com/download.php?i=f5f9654bb -O /etc/asound.conf
sudo wget http://pastebin.com/download.php?i=f2e38265 -O /usr/share/alsa/cards/HDA-Intel.conf
Surely this isn't rocket science and should be easily doable. Some help please? I feel dumb :x
edit:
Followed this tutorial. Still no luck.
http://wiki.xbmc.org/index.php?title=HOW...controller
The test (speaker-test -D hdmi -c6 -r19200 -FS32_LE) gives surround sound though. And if I open XBMC and let it idle in the menu it says resource busy during the test.
edit2:
I removed XBMC 11 pre and installed XBMC 10.1 through the maverick PPA. If I adjust the audio settings to:
Audio Output Device: Internal Audio Digital Surround 5.1 (HDMI)
Passthrough Output Device: hdmi
I do in fact get sound in my SD movies (mp3 codec etc). But I want audio on my highdef movies as well. And actually ... I prefer the 11 pre version as well. But as a test I guess it was succesful. If I use the custom audio devices (hdmi:CARD=NVidia) it doesn"t work either.
Audio Output: HDMI
DTS capable: yes
edit:
edit2:
