i agree tho, you might not need built-in WiFi / SATAIII / eSATA features too!
Yes but everyone needs something to have a good argument about
rufrothy Wrote:Hmm....
So this would work with the new ASRock and the AMD A4-3400
http://www.ebay.com/itm/IR-Receiver-w-Ca...4cf82c7a64
That is great, as I just found out that the Asrock motherboard has a CIR but does not come with the remote.
What I am more interested in is this;
http://asrock.com/mb/spec/Card.asp?Model=Smart%20Remote
It uses an external USB IR unit (that plugs into a USB port and the CIR header via internal cabling) rather than having to drill your case. I just need to find a place I can buy it from and I need to make sure it will work with XBMC.
The
voip-ninja Wrote:That is great, as I just found out that the Asrock motherboard has a CIR but does not come with the remote.
The
Cool. Keep us posted how this works out.
voip-ninja Wrote:I just need to find a place I can buy it from
and thats the hard part,,,
better to get a motherboard that comes with it by default,,,
rufrothy Wrote:Cool. Keep us posted how this works out.
Will do. I emailed tech support to see if they knew how I could get it. I found an internal USB header on eBay that is about $28 shipped so that will be my backup option if ASRock cannot hook me up.
voip-ninja Wrote:Will do. I emailed tech support to see if they knew how I could get it. I found an internal USB header on eBay that is about $28 shipped so that will be my backup option if ASRock cannot hook me up.
most asrock mobos included cir option. their mce remote control and usb multi-angle cir remote receiver are the best option. some of their mobos included these options in the package. you should be able to contact asrock to aquire it!
the cir in e350m1 is located next to usb8-9 and certain models bundles with mce remote control/multi-angle cir receiver (
asrock Z68M-ITX/HT- cir located next to usb6-7).
bluray Wrote:most asrock mobos included cir option. their mce remote control and usb multi-angle cir remote receiver are the best option. some of their mobos included these options in the package. you should be able to contact asrock to aquire it!
Thanks! I did inquire as to how I could get this. All I really need is their USB IR unit and then just wire that USB port to the CIR/USB headers on the case. I already have a Harmony One.
I would also imagine there are some ASRock owners who do not use the CIR unit at all, so I have inquired on Tweak Town's ASRock forum about anyone willing to sell it to me.
eskro Wrote:The Power ON and OFF feature seems so wanted in the HTPC market nowadays...
I have to admit that i enjoy this feature very much on my own HTPC!
Since i've been asked alot on how I've done it,
i thought i'd simply share the 'known' ways to achieve this...
Note that there's probably other ways too,
but those are the ones i know,.,
Ok, Here we go...
METHOD#1
I guess i could start by saying that depending on the case you buy,
if it comes bundled with a remote control and some sort of IR Receiver LCD Screen,
like the SST-GD02B-MT case,
chances are that you'll be able to Power ON and OFF your HTPC...
So you'll have to do your own research here before buying your case...
Like me, i bough the Antec MicroFusion350 htpc case,
and it was bundled with a remote control...
it works hand in hand with its LCD Screen which is also an InfraRed Receiver...
So after putting all my htpc together and installed all needed drivers,
i was able to Power ON and OFF my HTPC...
Of course, it even works with my Harmony 300i remote!
so, yeah, thats 1 way to do it,,,
METHOD#2
to continue a bit about ANTEC here,
ANTEC released some InfraRed Receivers you can use to enable such a feature....
To name a few:
*Antec VERIS Basic Infrared receiver
*Antec VERIS Elite Infrared receiver
the basic version fits in an external 3.5" Drive bay
while the Elite version fits in an external 5.25" Drive bay...
so keep that in mind before buying either of them,,,
Anyhow, once you hook them up,
Of course, it'll even work with any Harmony remotes aswell!
so, yeah, thats another way to do it,,,
METHOD#3
SIMEREC.COM's PCS-2 Universal IR Remote Switch
is a neat little InfraRed Receiver that once installed,
you'll be able to to Power ON and OFF your HTPC...
There's a little bit of work involded here to make it work,
as you need to drill a tiny whole in your HTPC case to install the IR receiver..
But on the other hand, it comes fully assembled and no soldering is required!
this thing works with 99% of IR remotes on the market including Harmony's!
But note that as of today, this wont allow you to control your HTPC,,,
I've talked with the guys at simerec.com and they said that by the END of october,
they should release a version of their 'Universal IR Remote Switch'
which will also enable users to actually control their HTPC's!!
This is great news! good job SIMEREC!!
METHOD#4
you now what a CIR enabled motherboard is?
CIR stands for 'Consumer InfraRed'...
Not all motherboards have a CIR header though...
Becareful when buying your motherboard if you want such a thing...
Anyhow, once you found a CIR enabled motherboard,
all is left for you to buy is a compatible CIR module to plug it in!
And thats usually the hard part,, these modules are very hard to find..
Ebay is probably your best chance but even then, good luck,,,
After doing some research, i stumbled upon ASROCK's website,
and i saw at least 3 CIR enabled motherboards
but the greatest thing here is that they also bundled them with not only an IR remote
but also with a compatible CIR module!!
Nice job ASROCK!!
Here are those 3 CIR enabled ASROCK motherboards that i know of...
*ASRock H67M-GE/HT (B3) LGA1155 Micro-ATX
*ASRock Z68M-ITX/HT LGA1155 Mini-ITX
*H67M-ITX/HT LGA1155 Mini-ITX
Again, this should also compatible with any Harmony remotes aswell!
Finally,
i hope you've enjoy'ed the read and learned something along the way!!
~peace~
Hi eskro, first time post so a bit of a newbie but would this do.
http://www.pulse-eight.com/store/product...apter.aspx:grin:
blackbango Wrote:Hi eskro, first time post so a bit of a newbie but would this do.http://www.pulse-eight.com/store/product...apter.aspx:grin:
I see a lot of talk on ocuk about these ... why don't you get stuffed and go back there
{ Yes that's my way of saying welcome to the forums
eskro Wrote:and thats the hard part,,,
I just heard back from ASRock support in Chino, California. They will provide the USB CIR receiver for only $8 which includes shipping. Rather glad now that I did not spring for an extra $50 for a higher end motherboard that included it.
I'm not sure if it will work with other, non ASRock motherboards but $8 is a heckuva lot cheaper than anywhere else for this thing.
voip-ninja Wrote:I just heard back from ASRock support in Chino, California. They will provide the USB CIR receiver for only $8 which includes shipping
thats great news then!
http://www.asrock.com/support/faq.asp?id=275
all you need is a htpc case with front USB and your good to go!
