Since the support thread for xbmc 10.0-9 has been closed, I presume there's a new version out, but, which is it? There is no update available in nitotv installer, and eventhough I've done all the patches described in the closed 10.0-9 thread, there are some movies that simply stutter badly without apparent reason (the proper audio and video codecs that are reported to work). Which way to go and/or is there a new version? I'd prefer to not get into nightlies.
there is no newer "official" build then 10.0-9. but why not trying the nightlies? they are pretty good and pretty fast.
Nightlies are considered official because they come from Team XBMC (via a bot). Ever since the bot got up and running there's really been no reason do make new Cydia deb versions (the ones you install via NitoTV, etc). See:
http://wiki.xbmc.org/index.php?title=Ins...htly_build
Ned Scott Wrote:Nightlies are considered official because they come from Team XBMC (via a bot). Ever since the bot got up and running there's really been no reason do make new Cydia deb versions (the ones you install via NitoTV, etc). See: http://wiki.xbmc.org/index.php?title=Ins...htly_build
Thanks! indeed, pretty straightforward to get to nightlies, and such improvement in stability!
