2012-02-02, 01:03
2012-02-02, 17:25
You are welcome, damos!
I am glad that I could help you.
Have you done something extra or just followed my steps?
2012-02-09, 19:11
No, no... I have just followed your steps and all OK.
2012-02-20, 19:05
I just recently bought zotac ad10 and Im trying to configure the remote. Reading the previous posts, I'm a bit confused.
Can someone offer a step by step instructions?
.reg link is dead as well.
Also how do you configure the windows button on the remote, so that I can open xbmc?
2012-02-24, 01:44
I, too, am a new owner of an AD10 and I'm new at configuring this stuff.
I am unable to get any RC-response from the color keys / info. I have modified CreateTestConfig.reg, substituting 745a17a0-74d3-11d0-b6fe-00a0c90f57da for 745a17a0-74d3-11d0-b6fe-00a0c90f57df, applied it and rebooted. I don't understand why ShowKey20 still can't get any signal from those special keys.
Please help..
Please help..
2012-02-25, 15:18
Anyone?
2012-03-15, 19:49
I'm in the process of setting up XBMC 10 on my AD10 (Windows 7 Pro x64); does anyone have easy setup files I can just run that will make the remote work better?
I.e., how some of you have the colour keys doing options (I know, that can be a person preference, but Id love to start with someone else's preferences then modify as needed).
2012-03-16, 03:29
(2012-02-20, 19:05)Yeloman Wrote: [ -> ]I just recently bought zotac ad10 and Im trying to configure the remote. Reading the previous posts, I'm a bit confused.
I'd love this to!
2012-04-29, 18:48
I am running XBMCbuntu on my ZBox AD10 and several button of the Zotac Remote work, but not all. Especial not being able to use the "info" button is extremely inconvenient. I have been searching around but most solution seems to be for windows based system or mention the MCERemote addon, which I cannot find in the repository.
Considering the popularity of the ZBOX, it seems to me many people should be facing the same problem. Anyone got a solution?
2012-04-30, 11:35
2012-04-30, 16:12
if someone could post a easy step by step guide for this remote/box combo i would apreciate it. i just started using XBMC so please take it easy on me. I have the remote kinda working. All i want to do now is get the info button to work and remap one button for context menu. i managed to get the green button remapped to launch XBMC instead of WMC.
Thank you in advance
running win 7 ultimate 64 bit/ 4 gb ram/ 120 gb ssd. Zotac Nano AD10
2012-05-01, 12:02
See this post, http://forum.xbmc.org/showthread.php?tid...pid1002837 and other comments in the thread. See http://wiki.xbmc.org/index.php?title=Usi...in_Windows for some background about what the .reg file does.
2012-05-01, 15:36
(2012-05-01, 12:02)jhsrennie Wrote: [ -> ]See this post, http://forum.xbmc.org/showthread.php?tid...pid1002837, and other comments in the thread. See http://wiki.xbmc.org/index.php?title=Usi...in_Windows for some background about what the .reg file does.
i do not understand this part
When I found that, I applied the CreateTestConfig.reg file to the 745a17a0-74d3-11d0-b6fe-00a0c90f57df key.
After that using the ShowKey20.exe tool I could find the RC keys ID's for the Info and coloured buttons (CB for Info, and 6D,6E,6F,70 for red, green, yellow, blue).
that is why i am asking for help.
2012-05-01, 18:56
I don't have an AD10 so this isn't something I can test.
eHome remotes can generally be configured by modifying a registry value. The MCERemote and other similar tools work by modifying this registry value. It appears that the AD10 uses a different registry value from other eHome remotes so MCERemote can't configure it. To configure your AD10 you'll need to get a suitable registry file from someone. I can't make you one because I don't have an AD10 to test with, however the post I linked to has a likely looking registry file. You can copy and paste into Notepad then save as, for example, AD10.reg. Doubleclicking the file should then make the required changes.
2012-05-01, 20:26
ok thank you i will try this and post back if it worked
