Full Version: Change Button Behavior
Hi, I was wondering if it is possible to adjust the behavior of buttons. I am using XBMC on the apple tv 2g and I would like to have movie info come up when a movie title is selected. Currently pressing the select button will play the movie while holding the select button down will bring up the movie info. I would like to reverse this behavior but I am unable to find where to do this.
Any help would be greatly appreciated. Even if you could just point me to the correct file(s) I might be able to figure it out.
No need to edit files. Just go into settings->video->file lists and change the default action from play to show information.
Thank you, that worked great, however is it possible to make it play the movie if I hold the button down? If not then I will just live with it this way. Thanks again.
No, long pressing to perform an action isn't possible afaik.
Actually I just figured out how to change the keymap for the remote and was able to make it do what I wanted. Thanks again.
