Is it possible to force XBMC to use the already downloaded images and fan-art that I used Ember to scape? When updating my library I notice it uses default images from what ever it finds but with ember I have already chosen certain images that I want to appear in my list such as fan-art and cover art etc... I get a lot of other language covers that I don't particularly like.
XBMC always prioritizes local nfo and images. How have you configured your scraper and how is your Ember install configured to name your images/fanart?
Here is a list of files for the movie Your Highness
/extrathumbs
movie.nfo
movie.tbn
Your Highness.nfo
Your Highness.tbn
Your Highness.avi
I have never had XBMC not use my local images, with the exception of artist thumbs and fanart which I can't figure out how to update once XBMC has loaded from the internet first.
fluentdesigns Wrote:Here is a list of files for the movie Your Highness
/extrathumbs
movie.nfo
movie.tbn
Your Highness.nfo
Your Highness.tbn
Your Highness.avi
you can delete half of these files. Either use 'movie....' or 'Your Highness...'
No need to have this double.
How about fanart?
Can I remove the <movie>-fanart.jpg as well and just use fanart.jpg?
fluentdesigns Wrote:How about fanart?
Yes, just use fanart.jpg, movie.tbn, movie.nfo and movie-trailer.<ext>.
If you chose to use movie.... set the scraper in xbmc to 'use foldernames for lookup'
His file structure led me to believe that everything was in it's own folder. He's using /extrathumbs for example.
Indeed, they go in the movie folder NOT extrathumbs.
clubwerks Wrote:I have never had XBMC not use my local images, with the exception of artist thumbs and fanart which I can't figure out how to update once XBMC has loaded from the internet first.
Context menu > Get fanart.
/extrathumbs
movie.nfo
movie.tbn
Your Highness.nfo
Your Highness.tbn
Your Highness.avi
What they are telling you is your folder structure should look something like this:
C:\MOVIES\
Movie.Title.year\
-----^-Movie.Title.year.mkv
-----^-Movie.Title.year.nfo
-----^-Movie.Title.year.tbn
note, the filenames below work just as well as long as 'use folder names for lookup' is enabled.
movie.nfo
movie.tbn
Hitcher Wrote:Context menu > Get fanart.
I don't want to do that. Even when I do that for get thumb, it doesn't always work. I want XBMC to use what I've put in the artist folder automatically.
so what does the .tbn file hold? the cover art? which would be folder.jpg?
Should be indeed the same as folder.jpg/tbn or poster.jpg/tbn
