Full Version: [RELEASE] Bticino Legrand Commander lights (Home Automation)
Bticino Commander Lights
V0.0.1October 2011
- Initial release for My Home Bticino / Legrand
Description:
Starting on the Shoop_NL’s great work for X-10 protocol (http://forum.xbmc.org/showthread.php?tid=110392), I deveolopped an Add-On Controls lights for the Bticino / Legrand system during watching of a video.
The Addon work only with Eden.
Configuration posibilities:
• IP-address to host
• Port number of Bticino / Legrand Gateway
• 10 My Home commands (On, Off, Dim level) for XBMC Events
• 10 My Home command (On, Off, Dim level) for each PLAYER Events
Usage:
When starting or stopping XBMC:
you can on / off or set dimmer level of Lights (Bticino)
When watching (Start, Stop, End, Pause and Resume) a video:
Video:
http://www.youtube.com/watch?v=r1UIaVA0F_8
Prerequisites:
A Bticino / Legrand webserver/gateway (F452, F453, F453AV, MH200, MH200).
The IP address of your XBMC client into the Bticino IP range as explained here.
http://www.myopen-legrandgroup.com/resou...33994.aspx
http://www.sdomotica.com/xbmc/Tutorial_T..._range.pdf
Downloads:
Add-On
Install:
Make sure you have downloaded the service add-on, service.MyHome-lights.zip
Extract service.MyHome-lights.zip
Copy the folder as following, please be careful to put in the right folder
The add-on is now installed, if you left XBMC running during the instalment, it will become available after a new startup of XBMC
Screenshots:
Enjoy with it
Sdomotica.com
Pfeifer
Hello,
will you make an update with new XBMC version.
It could be nice ;-)
Thanks a lot for that job
