Full Version: Fusion MOD by EKIM232
I decided to post my version of Fusion since I figured someone else might want to give it a try. I am not really taking on many feature requests since I am in limbo on all my work until Eden comes out, but I will entertain some or bugs if there is a need. This was simply just me messing around with Fusion to make it more the way I prefer to have things. Much thanks to Arcanthur for making this great design and to frellAn and Crookas for their MOD pieces I also borrowed in places.
Main features/changes
- New homepage style.
- Custome home menu items. Can also press up and select a default icon once your new menu item is added.
- Changed/added/removed views to make them more my style.
- Works with banner.jpg and landscape.jpg - Posters being default.
- Several additions for add-ons in settings.
- Custome backdrops for homepage.
There is a some other stuff, but you will see once you check it out. Enjoy!
DOWNLOAD
[Image: screenshot000b.png]
Uploaded with ImageShack.us
thanks downloading now. it would be nice if there's any screenshot.
This is really nice. I have just tried it and I think I will keep it for a long while. Smile
One question though, how can I get rid of the "Windows: home (Home.xml) Mouse...." message on top?
kyotocafe Wrote:This is really nice. I have just tried it and I think I will keep it for a long while. Smile
Go to the skin's directory
\addons\skin.fusionEKIM32
Edit the addon.xml file
Change this line:
debugging="[b]true[/b]"/>
to
debugging="[b]false[/b]"/>
Save and restart XBMC
I just fixed the debugging setting and uploaded a new file. Thanks for catching that!
@ekim232: now that eden has got into a soft freeze, will you start again on PRESCENCE?
Rygrath Wrote:Go to the skin's directory
Change this line:
to
Thanks! It worked great.
I have also found another bug. When going to the Videos section from the main menu, I am getting the list of files but I am not able to browse through them.
I can only go back to the main screen or get a menu with only "Settings" on it.
[Image: screenshot005h.png]
[Image: screenshot004r.png]
I have also found another bug with the movies views:
When playing a song, the cdart is overlapping the media flags:
[Image: screenshot007x.png]
It is not happening with the shows view:
[Image: screenshot008b.png]
EDIT: I just realised it also happens on the shows views as well, only that the previous screenshot was not displaying media flags Smile
[Image: screenshot009oj.png]
Thanks for pointing out the bugs. They are all easy fixes. I will address them tonight and upload a new version.
All reported bugs fixed and new version uploaded. Thanks for pointing them out!
ekim232 Wrote:All reported bugs fixed and new version uploaded. Thanks for pointing them out!
I have tried downloading the link on the first post, but it looks like it is the same version that was first uploaded since the bugs are not fixed and I am getting to see the same debug message as before:
[Image: screenshot012yd.png]
I think you need to remove the skin and do a fresh install. I just downloaded the version I have uploaded to mediafire on a new htpc and it does not have the bugs. See screenshot below.
[Image: screenshot001fn.png]
I finally got it working. I had already removed and reinstalled the skin several times. I tried it on an eden installation and it was working good without the bugs. So... it was definitely an issue with my Dharma setup.
Thus, to sum up, what I did is to install it on another system and then copy the skin folder to my Dharma folder on my main system. Kind of weird but it worked, and I have to say that all previous mentioned bugs were indeed fixed.
Thanks so much Smile
(2011-10-04 03:36)ekim232 Wrote: [ -> ]I decided to post my version of Fusion since I figured someone else might want to give it a try. I am not really taking on many feature requests since I am in limbo on all my work until Eden comes out, but I will entertain some or bugs if there is a need. This was simply just me messing around with Fusion to make it more the way I prefer to have things. Much thanks to Arcanthur for making this great design and to frellAn and Crookas for their MOD pieces I also borrowed in places.
DOWNLOAD
Thanks for information
iklan gratis
Reference URL's
