Hi;
Can any one help me out how I can control Apple TV2 away from home using the internet. I want to transfer files to ATV2 such as repo zip files. Any help is very welcome.
ftafartout Wrote:Hi;
figure out what the default port you connect to it is on, forward that port, and SSH/SFTP in from a remote location..?
Log on to your router's web interface and find the port forwarding menu. Forward any WAN port (my suggestion is the default port for SSH, 22) to port 22 on your ATV. Now you can SSH to your ATV from the outside. If you forwarded port 22, you don't have to specify a port, just point the SSH client to your WAN IP.
PuTTY is a great, free SSH client.
Once you're logged on to your ATV, if you want to download stuff that's available on the internet, just use wget. If you haven't got it installed on your ATV already (you can check that by simply trying the command wget), install it with
apt-get install wget
Then download the files you want:
An example:
wget http://mirrors.xbmc.org/nightlies/darwin/atv2/xbmc-20111005-fc24dcb-master-atv2.deb
I haven't tried if SCP works with the ATV's sshd, but if it does, I'd guess thats the best way (or at least the easiest as you don't have to forward any additional ports once you've set SSH forwarding up, or configure anything on your ATV) to transfer locally stored files to the ATV.
WinSCP is a decent SCP client.
Anyone know the atv2 root password too, this is a very good way to expose your internal net to the script kiddies.
davilla Wrote:Anyone know the atv2 root password too, this is a very good way to expose your internal net to the script kiddies.
^ This. If you do this you'll want to change your root and mobile passwords.
I think we should automate the opening of firewall ports too... you know, to make it easier and faster.
Most routers allow forwarding any port to another. To reduce abuse I strongly recommend using a non-standard port on the router. The script kiddies davilla referred to tend to scan for port 22 on external IPs.
jd2157 Wrote:I think we should automate the opening of firewall ports too... you know, to make it easier and faster.
no way do I want a device automatically opening up an ssh port on my firewall, especially when said device ships with default root passwords
As long as you change the default passwords there shouldn't be an issue. I've done this myself many times in the past.
Other than ssh, I also use the VNC service on Apple Remote Desktop to help friends whom I have setup atv2 for. Ofcourse you also need to have Exposed installed on the relevant atv2 which is done through Nito tv.
