Hi
I've just started having two problems
1. when I go into music and then into an album XBMC crashes.. I have tried other skins and it apperars to be ok..
2. not seeing background jpeg for movies on home screen
im using Eden pre version Back Row from your link
and XBMC version XBMCSetup-20111006-746f7b2-master.exe
any help
thanks in advance
Borg101
Hi Borg101
I've just been testing this and I don't seem to be able to reproduce these errors.
For me the album thing isn't happening in library or file mode. I suppose a debug log would be helpful if you could post one?
For your second issue around movie fanart on the homescreen (using the recently added list I'm assuming?) you only get fanart displayed if you are using multiple home wallpapers and not the default red curtains wallpaper. Is that maybe the problem?
Cheers
will upload crash log for you
thanks
ok found crash log hope this helps.. some more info to help you
im using music file mode not library..
it appears to crash mostly when there are alot of mp3's in one folder ie. best of the 80's with about 40 mp3's in there.. it crashes when scanning media
im using coverflow and it olny appears to happen when using coverflow tried list and list 2 they work ok
Oh no sorry I meant post the xbmc.log rather than the .dmp fiile. Just copy it to pastebin and post a link.
I wonder if it's a memory thing? - I'll see if I can reproduce it using your extra info.
Cheers
Okay I've replicated it - it seems to be related to some things running in the background - TV Next Aired, Weather Plus etc.
Cheers Sharpe
hope this helps
14:15:14 T:3936 NOTICE: -----------------------------------------------------------------------
14:15:14 T:3936 NOTICE: Starting XBMC, Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Oct 7 2011 (Git:20111006-746f7b2, compiler 1600)
14:15:14 T:3936 NOTICE: Intel(R) Atom(TM) CPU 230 @ 1.60GHz
14:15:14 T:3936 NOTICE: Desktop Resolution: 1920x1080 32Bit at 59Hz
14:15:14 T:3936 NOTICE: Running with administrator rights
14:15:14 T:3936 NOTICE: Aero is enabled
14:15:14 T:3936 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
14:15:14 T:3936 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
14:15:14 T:3936 NOTICE: special://masterprofile/ is mapped to: C:\Users\XBMC\AppData\Roaming\XBMC\userdata
14:15:14 T:3936 NOTICE: special://home/ is mapped to: C:\Users\XBMC\AppData\Roaming\XBMC
14:15:14 T:3936 NOTICE: special://temp/ is mapped to: C:\Users\XBMC\AppData\Roaming\XBMC\cache
14:15:14 T:3936 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
14:15:14 T:3936 NOTICE: Log File is located: C:\Users\XBMC\AppData\Roaming\XBMC\xbmc.log
14:15:15 T:3936 NOTICE: loading special://masterprofile/guisettings.xml
14:15:15 T:3936 NOTICE: Getting hardware information now...
14:15:15 T:3936 NOTICE: Checking resolution 12
14:15:15 T:3936 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:15:15 T:3936 NOTICE: Loaded playercorefactory configuration
14:15:15 T:3936 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:15:15 T:3936 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:15:15 T:3936 NOTICE: No settings file to load to load (special://xbmc/system/advancedsettings.xml)
14:15:15 T:3936 NOTICE: No settings file to load to load (special://masterprofile/advancedsettings.xml)
14:15:15 T:3936 NOTICE: Default DVD Player: dvdplayer
14:15:15 T:3936 NOTICE: Default Video Player: dvdplayer
14:15:15 T:3936 NOTICE: Default Audio Player: paplayer
14:15:15 T:3936 NOTICE: Loading media sources from special://masterprofile/sources.xml
14:15:17 T:3936 NOTICE: initializing playlistplayer
14:15:17 T:3936 NOTICE: DONE initializing playlistplayer
14:15:18 T:2428 ERROR: CRemoteControl::Connect - failed to connect
14:15:19 T:3936 NOTICE: initialize done
14:15:19 T:3936 NOTICE: Running the application...
14:15:19 T:3936 NOTICE: ES: Starting event server
14:15:19 T:3132 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
14:15:19 T:3132 NOTICE: UDP: Listening on port 9777
14:15:19 T:672 NOTICE: -->Python Interpreter Initialized<--
14:15:19 T:3936 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
14:15:27 T:3936 ERROR: Control 21 in window 10000 has been asked to focus, but it can't
14:15:28 T:3936 ERROR: Window Translator: Can't find window muciclibrary
14:15:28 T:108 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(addons) in addons://sources/../fanart.jpg
14:15:28 T:108 WARNING: Previous line repeats 1 times.
14:15:28 T:108 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(addons) in addons://sources/audio/fanart.jpg
14:15:38 T:3936 WARNING: Previous line repeats 1 times.
14:15:38 T:3936 ERROR: exception in CApplication::FrameMove()
14:15:38 T:3936 ERROR: exception in CApplication::Render()
14:15:38 T:3936 ERROR: m_pD3DDevice->BeginScene() failed. 8876086C - D3DERR_INVALIDCALL (Invalid call)
14:15:38 T:3936 ERROR: CApplication::FrameMove(), too many exceptions
Okay thanks for that - I've uploaded some fixes that might help. Give it a try and let me know.
Cheers
cheeers Sharpe for taking the time to look..
tried the new downloads today
sorry but it hasn't fixed the fault..
just tring to think of anymore info I can give you
I have noticed that the folders do tend to have fanart jpegs in them
Cheers Borg101
No worries - I'll have a proper dig into it soon and update you when I have figured it out.
Hay Sharpe
I've just updated to latest nightly and the problem is fixed..
touchwood..
thanks Borg101
