Hi, Stoli! Thank you for the beautiful skin, more than six months I'm using only Neon.
And now I have a little question - is there a way to use animated weather icons with Neon? I'm found weather icon pack in Media folder, but animation is don't work...
You would have to replace the current icons with animated ones - I'm sure there is a pack somewhere you can download and replace them with.
stoli Wrote:You would have to replace the current icons with animated ones - I'm sure there is a pack somewhere you can download and replace them with.
I know that Aeon has animated weather icons, but AFAIK just dropping them in the theme folder won't work as it's actually a group of PNGs that are looped as 'frames' to create the animation, so unless neon is already looping a single file it probably won't work.
just wondering if any update on using animated weather icons on neon. anyone using them or know how to?
