2011-10-10, 02:58
I currently have XBMC setup on a laptop (win7 64 bit) connected to a server - working great !.
I transfered the userdata folder from it to a new stand alone pc (Win7 32 bit) so I wouldn't have to go through the scraping and renaming routine again.
When I start XBMC on the stand alone pc, my library (library mode) shows up w/thumbnails and fanart just as I want but when I select the movie I get the message: file no longer available, do you want to remove it ?. If I go to the "root" view, everything shows up and plays properly.
I tried editing the sources folder as such: (all movies are on the root of the drives, as are the tv shows)
<?xml version="1.0"?>
-<sources> -<programs> <default pathversion="1"/> </programs> -<video> <default pathversion="1"/> -<source> <name>Tv</name> <path pathversion="1">D:\</path> </source> -<source> <name>Movies</name> <path pathversion="1">E:\</path> </source> </video> -<music> <default pathversion="1"/> </music> -<pictures> <default pathversion="1"/> </pictures> -<files> <default pathversion="1"/> </files> </sources>
but the "link" is still not found. Does the edit look ok ?
Could the problem be in the userdata\database\MyVideos34 database file?
If so, can this be "reindexed" or modified somehow to sync up with the other information ?
Could it be a Win7 64 bit vs 32 bit thing ?
Thanks for any advise
