Full Version: (Un)Clean Install
My Theater PC has gotten a bit sluggish and some codecs are messed up on it, even in XBMC some of the images display as ghost images instead of proper and there are other issues as well. So what I am wanting to do is a complete re-install of Windows 7 fresh, but at the same time a LOT of energy and effort has been put into setting up XBMC correctly. My movies and data etc are on separate drives, and I plan to install the drives on the fresh install with the same drive letters as well.
What I would like to do is copy all pertinent data for XBMC to a backup drive, and then reinstall XBMC on the new install followed by copying or moving the backup folders to their proper places (from c:/program files/XBMC and from C:\Users\PROFILENAME\AppData\Roaming\XBMC). If i do this will everything copy over correctly? Any other prep I should do? Thanks!
Only copying the folder from c:\user\.... will be enough. Copying the install won't be neccasary cause the new install of xbmc will do that.
