Hi;
Can any one help me out to find where the files stored in apple tv2 when you do install from zip for add-ons. Any help is very welcome
Pretty much anywhere but...
Its best to create a folder for it and keep it organised within the user data folder so it is available for restoration if need be.
Another alternative which many prefer is to go to Filemanager in XBMC and nominate a folder that is shared on your mac/pc. This way you will be able to install form zip file directly from your computer as well as having the folder available for remote downloads for add ons that support the function.
I want to know where the file will go after you do install from zip.
private/var/Library/Preferences/XBMC/userdata/addons/
