Full Version: Start "Playing" Music Album hangs up XBMC
Hi there,
I have installed XBMC according the link http://wiki.xbmc.org/index.php?title..._on_Apple_TV_2 given in this forum.
Installation went well and XBMC system info shows XBMC version 11 was installed.
When I press "P" for Play on a music album - nothing happens.
I have to press "M" and "Space Bar" in order to get music to "pause" and
pressing spacebar again - music starts.
I am connected via UpNP to my Network Storage.
Is there a solution or workaround for that issue??
Thanks for any hints.
I am not sure what you are going on about with the keyboard commands, but even if they worked, the playback would be rubbish unless you upgrade to the nightly build.
ps your link is busted. it actually has '...' in it.
