2011-10-13, 15:22
Hello,
I try to use XBMC Live on my Dell Laptop with intel Centrino.
I have no problem with the installation, but i can't configure my wlan connection.
I install wicd-curses like it is explain in one of your guide, but when i start XBMC Live, wifi doesn't work.
However if i do CTRL+ALT+F1 and i log with my login/password the connection works.
Can you help me ? How make wicd start at the same time than XBMC ?
Thanks a lot
Thanks a lot
