Hey guys.
Organising TV Shows that XBMC would not pick up has always been such a boring task so i have made this application that should make it easier for you.
What this application does:
- Creates TVShow.nfo with fanart, thumb, genre and plot support
- Creates a episode NFO file for each tv show episode
- Can filter out parts of file names, eg (720p)
- Supports file filter, so that no unessacary nfo files are created
- Choose which season and episode you want for each TV episode
And much more
Download it here:
http://filebeam.com/d38b412c18942761af41f2718efd7388
Report any bugs you might get here, or to my mail
[email protected]
wow amazed no one posted about this, great little tool just what i was after for all my custom content
Unfortunately I can't get it to work. I get errors and .nfo files with wrong titles.
Any chance of an update?
FFY
(2012-02-09, 23:16)fungify Wrote: [ -> ]Unfortunately I can't get it to work. I get errors and .nfo files with wrong titles.
FFY
Not many seems interested in my application. However i'm willing to do an update if you could explain when the error occurs, and what the error message is.
-Tyranlol
Well I was interested in your app but I too am getting an error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Argument cannot be Nothing.
Parameter name: sourceFileName
at Microsoft.VisualBasic.FileIO.FileSystem.CheckFilePathTrailingSeparator(String path, String paramName)
at Microsoft.VisualBasic.FileIO.FileSystem.NormalizeFilePath(String Path, String ParamName)
at Microsoft.VisualBasic.FileIO.FileSystem.CopyOrMoveFile(CopyOrMove operation, String sourceFileName, String destinationFileName, Boolean overwrite, UIOptionInternal showUI, UICancelOption onUserCancel)
at Microsoft.VisualBasic.MyServices.FileSystemProxy.CopyFile(String sourceFileName, String destinationFileName)
at NFONator.Form1.Button3_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3634 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
NFONator
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/fff/My%20Documents/Downloads/XBMC%20NFO%20Gen.exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.3637 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.3639 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I get this error when I click GENERATE
Bloody shame too this looked like the perfect solution for me and very light weight.
thanks for the effort all the same
-b
Just stumbled across this
Is this program working now? Looks exactly what i need
I am interested....! very interested...! i have searched and searched for this... and never had any luck. decided to put "xbmc nfo creator" into google this time and BAM! i think the key word must have been creator or something as have found nothing before... I also have at least 3 friends who need to be told.
thanks
Hi Tyranlol,
it will be great if you continue to work on this !
I get the same the error. Hope you can get it it worked out.
I've been looking for something like this for years...I have over 800 tv shows and cartoons and this will come in handy for those stubborn tvdb scrapes. I just want my shows/episodes to appear as they named. I will test this out.
Edit: Well I got same error as well. Do you have to fill out every box?
I'm guessing that you can't batch process a whole TV show folder with different shows and episodes? This would be awesome if it could do that, download fanart, thumbs, etc..
