Full Version: intermittent crash while playing video (ATV2)
I'm still trying to determine if its related to a certain video or a problem in general, however my XBMC seems to be dumping me back to Atv menu intermittently while playing a movie. its happened on 3 different nightly builds so far. the most recent being the nightly from the 13th (xbmc-20111013-21de7b8-master-atv2.deb.) I've uninstalled XBMC, reinstalled, updated nightlies, etc.
aTV 4.3, xbmc installed and updated per Wiki Instructions
http://pastebin.com/GZdz5VUt xbmc.log
http://pastebin.com/D1R70QNM most recent file in crashreporter
syslog is too large to post, but i can drop box it if needed.
this is not a crashreporter file ... you grabbed the wrong one...
ok, i'll take a look at that tonight after work. also it seems to be related to the specific file i was playing so i'll grab media info then too. what file am i looking for in regards to the crashreporter, i followed this set of directions for finding logs, but "/private/var/mobile/Library/Logs/CrashReporter" was a little vague about which file, so i just grabbed the only one from that day. thanks for your help.
latest appletv or something like that ... not able to have a look onto my atv2 currently...
http://pastebin.com/ZzJYQW43 LatestCrash-AppleTV.plist
filezilla was reading it as a directory for some reason and gave me fits downloading it, but there ya go
General
Complete name : \\SERVERNAMEHERE\Videos\Movies\Fantastic Mr. Fox (2009) - 480p\Fantastic Mr. Fox (2009).avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 677 MiB
Duration : 1h 27mn
Overall bit rate : 1 084 Kbps
Writing application : transcode-1.0.2
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 27mn
Bit rate : 944 Kbps
Width : 848 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.097
Stream size : 589 MiB (87%)
Writing library : Lavc51.40.4
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 27mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 79.9 MiB (12%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 48 ms
Writing library : LAME3.97 (beta)
ran the file through handbreak 0.9.5 on apple tv 2 profile and the resulting video played without issue
