Hi Guys, I have installed the cydia vesion of the XBMC in my Jailbroked Ipad 1, with iOS 5, I can surf in the XBMC without problems, but when I try to play any Video, the application crash and reboot my Ipad.
Anybody can help me?
Regards,
Diego
A few post have said this. I can confirm this happens on my iPhone.
Here we go again, reports of crashes without crashreporter log or xbmc.log.
Have installed the latest IOS build 17/10/11 and it crashes as soon as i try to use the movies option. Will provide logs tomorrow (too late now, have to work tomorrow) xbmc.log doesn't contain any useful info. Will enable debug tomorrow and make it crash
Ipad 1, IOS 5 JB with redsnow.
Could not stand it to only tell and now show, so enabled debugging recreated the crash and uploaded the logs to pastebin.com
/private/var/log doesn't contain a syslog
/private/var/mobile/Library/Logs/CrashReporter contains lot's of files don't know which file you need so I took (but with earlier timestamp of tonight) LatestCrash-XBMC.plist:
http://pastebin.com/R1jBVCbr
xbmc.log
http://pastebin.com/AAz5pEBK
davilla hopefully you can find the culprit and smash it so this wonderful product can be shown with IOS 5.
what do you mean by "use the movies option" ?
From the home screen (using the latest touch skin from jezzx) tapping on movies (i,ve added a vido source and a couple of movies where scraped until the text "can'T connect o ... External site tvdb.com")
Wingie Wrote:From the home screen (using the latest touch skin from jezzx) tapping on movies (i,ve added a vido source and a couple of movies where scraped until the text "can'T connect o ... External site tvdb.com")
can you play or create thumbnails, basically anything that involves avcodec ?
Nope, as soon as I browse to any folder with videos in it the device cashes.
davilla Wrote:can you play or create thumbnails, basically anything that involves avcodec ?
Uhm maybe but don't have aclue how to achieve this? Will try to see if i can make xbmc create a thumbnail
Wingie Wrote:Uhm maybe but don't have aclue how to achieve this? Will try to see if i can make xbmc create a thumbnail
I was reading this earlier on my iPad and eating at the same time not a good combo. Now I understand your question, the same as hawx as soon as I go to movies it crashes.
I will try to delete all thumbnails that are already there and see what happens will also cleanup the crash reporter folder
Have deleted all thumbnails and removed xbmc.log and xbmc.log_old. Restarted XBMC went into Video's to check my Movie source it was still there.
Clicked on Movies and it showed me a list of my movies for a couple of seconds (names no thumbs) and then it crashed.
There is no crash reporter file dated with 18/10 and no syslog.
I'm trying to upload the xbmc.log but paste bin refuses claiming it's an empty paste (getting crazy from it) => I gave up so used another site
http://chopapp.com/#d4hy5q91
Edit 1:Tried it again and went into Video's => My source => got the file list and crash.
Edit 2: Updated to today's .deb file but with same end result.
PS: Hopefully an untether will be available soon so that I don't have to "Just Boot" each time with redsnow and press my home button almost to the back of my iPad ;-)
Wingie Wrote:Have deleted all thumbnails and removed xbmc.log and xbmc.log_old. Restarted XBMC went into Video's to check my Movie source it was still there.
I'm trying to upload the xbmc.log but paste bin refuses claiming it's an empty paste (getting crazy from it) => I gave up so used another site http://chopapp.com/#d4hy5q91
I have the same results with my iPad 1. I miss XBMC
I have the same problem with my iPhone 4 and my iPad 1 both devices are running iOS 5.
Basically the device reboots when i enter to the xbmc and go to the directory where the movies are. I can navigate in the xbmc menus all i want, but as soon as i enter to the directory where the movies are it crash and reboots.
Both devices are jailbroken with redsn0w.
I can send you the crash logs if you tell me where to find it, because in the logs directory are none.
Thx.
