Full Version: Lost library after update?
Hello,
I just updated my nightly build to the most recent (xbmc-20111015), however it seems that it is now going through and re-creating the library? I have over 2tb of TV Episodes stored on my network, and this process takes a few hours to complete... Does this happen normally? Or should I only be doing my "nightly" updates while I'm not looking to watch TV?!
PS, I use my iPad/iPhone to browse my library and rely on the library being available, too.
Any suggestions would greatly be appreciated!
Thanks,
Rob
Updating nightlies does not reset the library. You need to post a debug log: http://forum.xbmc.org/showthread.php?tid=92480
I would stop the library update, it should not be needed. From other posts there might be a problem with the Update on startup option being inverted on the last build.
If the problem exists - it should be fixed very quickly!
