Full Version: Menu's are all transparent?!?!
Hi Guys,
This is the second time now that this has happened. I am using the newest version of Aeon NOX and a nightly build from oct 10.
I will occasionally get the menus on everything (tv shows, the main screen menu) to have no black backdrop just showing transparent for everything.
I quit XBMC and came back to all the menus being transparent.
The first time this happened months ago I had to remove everything on xbmc and reinstall and rescrape and it was a pain. Is this a known bug? When I choose another theme it works fine.
Any suggestions?
i think that the problem is related to the updating of the skin.
if you do something, i don't understand yet what, while your xbmc is downloading the skin, all the skin could become trasparent.
when it happens i change to confluence and re-download the skin from the repo. (the download is fast, i think that it doesn't really download all the skin but it reset the wrong things).
Peppe
