Hey Guys,
I was trying to get a addon up and running that should do the following:
Add selected Track to playlist and Skip one forward...
Thought about something like this:
XBMC.Action(Queue)
XBMC.PlayerCommand(Next)
This didn't work for me...
So I tried digging the forum and found this thread:
http://forum.xbmc.org/showthread.php?tid=34198
I tried to follow the commands in there, but no success...
Maybe someone has a hint for me...Would be awesome...
As additional information: This should be realised using a Pre-Eden-Nightly
and later on the addon should later on be mapped to a key
Thanks for your help in advance.
cheers,
mad-max
el_Paraguayo Wrote:Not tried them yet myself.
I have now!
So yes, these should do exactly what you want.
Here's an example (although I haven't tested this in XBMC):
import xbmc
AddToPlaylist = xbmc.executeJSONRPC('{"jsonrpc": "2.0", "method": "AudioPlaylist.Add", "id": 1, "params": {"item": {[color=red]"songid": 7[/color]}}}')
if AddToPlaylist["result"] == "OK":
xbmc.executeJSONRPC('{"jsonrpc": "2.0", "method": "AudioPlaylist.SkipNext", "id": 1}')
The bit in red is how you add an item to the playlist. According to the wiki, you can pass any of the following:
[ Playlist.Id playlist ]
[ Library.Id songid = -1 ]
[ Library.Id albumid = -1 ]
[ Library.Id artistid = -1 ]
[ string file = "" ]
[ string directory = "" ]
[ Library.Id genreid = -1 ]
so it depends on what information you're passing to the script.
Happy to help more if I can.
the wiki was very confusing for me too because its not up to date. but i managed it by just reading, reading and reading stuff about JSON RPC. so the first thing would be to understand the syntax of JSON, you can find a simple introduction on wikipedia (or read the JSON reference):
http://en.wikipedia.org/wiki/JSON
the second thing to understand is what JSON RPC is. its an extension of JSON for remote procedure calls (that would be the queries you want to create). Wikipedia is your friend here too:
http://en.wikipedia.org/wiki/JSON-RPC
and finally you simply need a documentation what remote procedure calls are supported by XBMC. i suggest to download the current nightly build as this version has the most recent implementation of JSON RPC. then just send the command JSON.Introspect() whereas you will get a full description of all supported commands and parameters.
and a side note: you should subscribe to the following thread...
http://forum.xbmc.org/showthread.php?tid=98551
...to get a notification when montellese adds new functionality to the JSON RPC interface because its a pain in the ass to read the whole json development thread.
hope this helps.
Thanks for pointing me in the direction...
currently there is a problem here:
21:04:09 T:2504 NOTICE: -->Python Interpreter Initialized<--
21:04:09 T:2504 ERROR: Error Type: <type 'exceptions.TypeError'>
21:04:09 T:2504 ERROR: Error Contents: string indices must be integers, not str
21:04:09 T:2504 ERROR: Traceback (most recent call last):
File "C:\Users\max\AppData\Roaming\XBMC\addons\script.playlistenhancer\default.py", line 5, in <module>
TypeError: string indices must be integers, not str
Tried to get the result that will be returned an integer but no success... will report back if I found the solution...
mm
Hang on, I've forgotten to parse the output with simplejson...
I'll update in an hour or so.
el_Paraguayo Wrote:Hang on, I've forgotten to parse the output with simplejson...
Ok, try this:
import xbmc
import simplejson as json
AddToPlaylist = json.loads(xbmc.executeJSONRPC('{"jsonrpc": "2.0", "method": "AudioPlaylist.Add", "id": 1, "params": {"item": {"songid": 7}}}'))
You'll need to have script.module.simplejson installed and include it in your addon.xml file e.g.
<requires>
<import addon="xbmc.python" version="1.0"/>
<import addon="script.module.simplejson" version="2.0.10"/>
</requires>
Also, just to complicate things a bit more, the "AudioPlaylist" method doesn't exist in recent nightlies (see
this post).
I think it's just "Playlist" now.
The best way to check what's going on is take a look at the output of the "JSONRPC.Introspect" method.
That, and follow the JSON-RPC thread.
