Full Version: Memory suggestion for my first HTPC
Which memory would be better KHX1866C11D3P1K2/4G or KHX1600C9D3K2/4GX? Or would you suggest something different? Any suggestions would be highly appreciative.
HTPC setup = Gigabyte A75M-UD2H + AMD A8-3850
depending on what you're doing with the HTPC. I would say go with the cheaper memory. I don't think you will find much benefit from the slightly faster ram. The increase from a typical 2gb to 4gb (you are looking at 4gb) is the biggest speed increase to give a PC.
check my post #2.
